The Comgrow T500 3D printer sets a new standard in the world of 3D printing. Its advanced specifications deliver unmatched performance, making it a powerful tool for professionals and hobbyists alike. With a massive 500mm x 500mm x 500mm build volume, the T500 allows you to create intricate designs or tackle large-scale projects effortlessly. The dual Z-axis ensures stability, while the 49-point automatic leveling guarantees flawless first layers. These features work together to enhance precision and streamline your workflow, giving you consistent results every time. Experience how the T500 transforms your creative potential into reality.
  • The Comgrow T500 has a big build space of 500mm x 500mm x 500mm. This size is great for different projects and making many items at once.
  • Its strong metal hotend heats up to 300°C. This lets it work with many materials, even tough ones like carbon fiber.
  • The double Z-axis and Y-axis design keeps it steady. This reduces shaking and helps make accurate prints, even for tall or detailed designs.
  • The 49-point auto bed leveling system makes setup easy. It helps create a smooth first layer and is great for beginners.
  • WiFi lets you check and control prints from far away. This saves time and helps you work from anywhere.
Key Specifications of the Comgrow T500 3D Printer
Large Build Volume for Versatile Projects
The Comgrow T500 3D printer offers an impressive build volume of 500mm x 500mm x 500mm, making it ideal for tackling a wide range of projects. Whether you’re creating intricate prototypes or large-scale designs, this extra-large printing area provides the flexibility you need. You can print everything from functional parts to artistic creations without worrying about space constraints.
Tip: The large build volume is especially useful for batch production, allowing you to print multiple items simultaneously and save time.
Compared to standard build volumes like 350mm x 320mm x 325mm, the T500’s dimensions stand out, giving you more room to experiment and innovate. This versatility makes it a perfect choice for engineers, product designers, and small businesses looking to scale their operations.
High Nozzle Temperature and Material Compatibility
The T500’s all-metal hotend can reach temperatures of up to 300°C, enabling you to work with a wide variety of materials. From PLA and PETG to carbon fiber and TPU, the printer supports diverse filament types, ensuring you can choose the best material for your project.
Specification
Details
Up to 300°C
Filament Compatibility
PLA, ABS, TPU, PETG, Carbon Fiber, Wood
This high-temperature capability opens doors to advanced applications, such as printing durable parts or heat-resistant components. The hardened steel nozzle further enhances performance by resisting wear, ensuring consistent extrusion even with abrasive materials.
Note: The nozzle diameter options (0.4mm, 0.6mm, 0.8mm, and 1.0mm) allow you to customize your prints for precision or speed, depending on your needs.
Dual Z-Axis and Y-Axis for Stability
The dual Z-axis and Y-axis design of the Comgrow T500 ensures exceptional stability during printing. Equipped with dual motors, these axes minimize vibrations and maintain precise alignment, even during high-speed operations.
Key Features:
This robust structure eliminates common issues like layer shifting, resulting in smoother and more reliable prints. Whether you’re printing tall objects or intricate designs, the T500’s stability guarantees superior performance.
Tip: The dual-axis design is particularly beneficial for large-scale projects, where maintaining precision across extended print times is crucial.
49-Point Automatic Bed Leveling
Achieving a perfect first layer is crucial for successful 3D printing. The Comgrow T500 3D printer simplifies this process with its 49-point automatic bed leveling system. This feature scans the print bed at 49 distinct points, detecting even the slightest irregularities. It then adjusts the nozzle height dynamically, ensuring consistent contact between the nozzle and the print surface.
This advanced leveling system eliminates the need for manual adjustments, saving you time and effort. You no longer have to worry about uneven prints caused by an improperly leveled bed. Instead, you can focus on your designs while the printer handles the technical details.
Tip: Automatic bed leveling is especially helpful for beginners. It reduces the learning curve and increases the likelihood of successful prints from the start.
The 49-point system also enhances print quality. By maintaining a uniform first layer, it minimizes issues like warping or detachment. Whether you're working on small prototypes or large-scale projects, this feature ensures reliable performance every time.
High-Speed Printing and Resolution
Speed and precision are essential for efficient 3D printing. The Comgrow T500 excels in both areas, offering a maximum printing speed of 200mm/s. Its high-power motors and rapid acceleration of 8000mm/s² on the X and Y axes allow you to complete projects faster without compromising quality.
This high-speed capability is ideal for large-scale projects or batch production. You can print multiple items in less time, increasing productivity. Despite its speed, the T500 maintains exceptional resolution, delivering smooth surfaces and intricate details.
Details
Maximum Printing Speed
200mm/s
Acceleration
8000mm/s²
Layer Resolution
0.1mm - 0.4mm
The printer's internal linear rails play a significant role in maintaining precision. These rails reduce friction and ensure smooth movements of the print head, resulting in consistent layer alignment. This combination of speed and resolution makes the T500 a versatile tool for various applications, from artistic creations to functional prototypes.
Note: You can adjust the layer resolution to balance speed and detail. For intricate designs, choose a finer resolution. For faster prints, opt for a thicker layer.
The Comgrow T500 3D printer’s specifications prioritize both speed and quality, making it a reliable choice for professionals and hobbyists. Its ability to deliver high performance without sacrificing precision sets it apart in the 3D printing market.
Performance Enhancements of the T500
Superior Print Quality with Dual Axes
The Comgrow T500 delivers exceptional print quality, thanks to its dual Z-axis and Y-axis design. These axes work together to provide unmatched stability during printing. Dual motors on both axes ensure precise alignment, even when handling complex or tall designs. This feature minimizes vibrations and eliminates common issues like layer shifting, resulting in smoother and more detailed prints.
The industrial-grade linear rails further enhance the printer's performance by reducing friction. This allows the print head to move smoothly, ensuring consistent layer alignment. Whether you're creating intricate prototypes or functional parts, the T500's dual axes guarantee professional-grade results.
Tip: For best results, use the T500's automatic bed leveling system in combination with its dual axes. This ensures a flawless first layer and enhances overall print quality.
Faster Printing Speeds for Large-Scale Projects
Speed is a critical factor when working on large-scale projects or batch productions. The Comgrow T500 excels in this area, offering a maximum printing speed of 200mm/s. Its high-power motors and rapid acceleration of 8000mm/s² on the X and Y axes allow you to complete projects faster without compromising quality.
To put this into perspective, here's a comparison of the T500's speed with another popular model:
Printer Model
Maximum Speed (mm/s)
Comgrow T500
200
Creality K1 Max
500
While the Creality K1 Max offers higher speeds, the T500 balances speed with precision, ensuring that your prints maintain exceptional detail and quality. This makes it an ideal choice for creators who prioritize both efficiency and performance.
The T500's ability to handle high-speed printing without sacrificing resolution sets it apart. You can adjust the layer resolution to suit your needs, whether you're aiming for intricate details or faster production times.
Note: For large-scale projects, use the T500's large build volume and high-speed capabilities to maximize productivity.
Enhanced Stability with Internal Linear Rails
Stability plays a crucial role in achieving high-quality prints, especially for large or intricate designs. The Comgrow T500 incorporates internal linear rails on the XYZ axes, which significantly enhance stability and motion precision. These rails reduce friction, allowing the print head to move smoothly and accurately.
Here’s a breakdown of how the internal linear rails contribute to the T500's performance:
Provide stability and smooth motion, enhancing print quality.
Reduced Friction
Allows for precise and accurate prints by enabling smooth movement of the print head.
Improved Layer Alignment
Enhances stability, reducing layer shifting and warping, resulting in exceptional detail.
This advanced design ensures that your prints maintain consistent quality, even during extended print times. The improved layer alignment minimizes issues like warping or detachment, giving you reliable performance results every time.
Tip: The T500's stability features make it a great choice for printing tall objects or designs with intricate details.
The combination of dual axes, high-speed capabilities, and internal linear rails makes the Comgrow T500 a powerhouse in the 3D printing world. Its focus on stability and precision ensures that you achieve outstanding performance, whether you're a hobbyist or a professional.
Versatility with All-Metal Hotend and Hardened Steel Nozzle
The Comgrow T500 3D printer stands out for its ability to handle a wide range of materials, thanks to its all-metal hotend and hardened steel nozzle. These components are designed to give you the flexibility to experiment with different filaments, making the T500 a versatile tool for various applications.
The all-metal hotend can reach temperatures of up to 300°C, allowing you to print with high-temperature materials that many standard printers cannot handle. This feature opens up opportunities for creating durable, heat-resistant, or functional parts. The hardened steel nozzle enhances this versatility by resisting wear, even when printing with abrasive or exotic filaments.
Key Features of the T500's Hotend and Nozzle:
  • All-metal hotend capable of reaching 300°C.
  • Hardened steel nozzle for wear resistance.
  • Compatibility with abrasive filaments like carbon fiber and wood-filled PLA.
This combination makes the T500 ideal for projects requiring advanced materials. You can print with PLA, PETG, TPU, ABS, and even composite filaments like carbon fiber. Whether you're designing prototypes, artistic models, or functional components, the T500 gives you the tools to bring your ideas to life.
Tip: Use the hardened steel nozzle when working with abrasive filaments to extend the lifespan of your printer's components.
The ability to switch between nozzle diameters (0.4mm, 0.6mm, 0.8mm, and 1.0mm) further enhances the printer's adaptability. A smaller nozzle diameter provides finer details, while a larger one speeds up production for bigger projects. This flexibility ensures that you can tailor the printer's performance to meet your specific needs.
Nozzle Diameter
Best For
0.4mm
High detail and intricate designs
0.6mm
Balanced speed and precision
0.8mm - 1.0mm
Faster printing for large objects
The T500's advanced hotend and nozzle design also make it suitable for professionals and hobbyists alike. Engineers can create functional prototypes with durable materials, while artists can experiment with unique textures and finishes.
Note: Always ensure proper cooling when printing with high-temperature materials to maintain print quality and avoid warping.
The versatility of the Comgrow T500's all-metal hotend and hardened steel nozzle empowers you to explore new possibilities in 3D printing. Whether you're tackling complex designs or experimenting with innovative materials, this printer equips you with the tools to succeed.
User Experience with the Comgrow T500
Intuitive 7-Inch IPS Touchscreen with Klipper System
The Comgrow T500 enhances your 3D printing experience with its 7-inch IPS touchscreen. This vibrant display provides a clear and responsive interface, making it easy for you to navigate through settings and monitor your prints. The touchscreen operates on the Klipper system, a powerful firmware that simplifies control and boosts performance.
With the Klipper system, you can access advanced features without needing additional hardware. The interface is designed to be user-friendly, even if you're new to 3D printing. You can adjust parameters, start or pause prints, and troubleshoot directly from the screen.
Tip: Use the touchscreen to fine-tune your print settings in real-time for optimal results.
This combination of a high-quality display and intuitive software ensures that you stay in control of your projects at all times.
Easy Setup and Maintenance
Setting up the Comgrow T500 is straightforward, even for beginners. The printer comes partially assembled, so you can get started quickly. Clear instructions guide you through the process, ensuring that you don’t miss any steps.
Maintenance is equally simple. The modular design allows you to access components easily, making cleaning and part replacement hassle-free. The hardened steel nozzle and all-metal hotend are built for durability, reducing the frequency of replacements.
Key Features for Easy Maintenance:
  • Modular design for quick access to parts.
  • Durable components that require minimal upkeep.
Note: Regularly clean the nozzle and bed to maintain print quality and extend the printer’s lifespan.
This focus on ease of use ensures that you spend more time creating and less time troubleshooting.
Quiet Operation and Efficient Cooling Systems
The T500 operates quietly, making it suitable for home or office environments. High-quality stepper motor drivers minimize noise, so you can work without distractions.
Efficient cooling systems further enhance the user experience. The printer features three 3010 fans that ensure consistent material extrusion cooling. This prevents overheating and maintains print quality, even during long sessions.
Quiet Stepper Motors
Reduced noise for a peaceful workspace.
Triple Cooling Fans
Improved material cooling and print quality.
Tip: Place the printer in a well-ventilated area to optimize cooling performance.
The combination of quiet operation and effective cooling makes the T500 a reliable and user-friendly choice for any workspace.
WiFi Connectivity and Remote Monitoring
The Comgrow T500 takes convenience to the next level with its built-in WiFi connectivity. This feature allows you to control and monitor your 3D printer remotely, giving you the freedom to manage your projects from anywhere. Whether you're at home, in the office, or on the go, you can stay connected to your printer through your smartphone, tablet, or computer.
Tip: Use the WiFi feature to start, pause, or stop prints without being physically present. This saves time and keeps your workflow uninterrupted.
With remote monitoring, you can keep an eye on your prints in real-time. The T500's controllable LED lighting ensures visibility, even in low-light conditions. This means you can check the progress of your project at any time, ensuring everything runs smoothly.
Key Benefits of WiFi Connectivity and Remote Monitoring:
  • Start and stop prints remotely.
  • Monitor print progress in real-time.
  • Adjust settings without being near the printer.
  • Save time and increase productivity.
Imagine starting a print job before leaving for work and checking its progress during your lunch break. The T500 makes this possible, giving you more control over your time.
WiFi Connectivity
Remote control of the printer.
Real-Time Monitoring
Track print progress anytime.
Controllable LED Lighting
Better visibility in low light.
The combination of WiFi connectivity and remote monitoring transforms how you interact with your 3D printer. It simplifies your workflow, enhances productivity, and ensures you stay informed about your projects at all times.
Comparison with Competitors
Comgrow T500 vs. CR-M4
When comparing the Comgrow T500 to the CR-M4, you’ll notice several key differences that make the T500 a standout choice. The T500 offers a larger build volume of 500x500x500 mm, giving you more space to create large-scale projects or batch prints. In contrast, the CR-M4 provides a smaller build volume of 400x400x400 mm, which limits your creative possibilities.
The T500 also excels in speed and temperature capabilities. Its maximum nozzle temperature is higher, allowing you to work with a wider range of materials, including high-temperature filaments like carbon fiber. The CR-M4, on the other hand, supports standard nozzle temperatures, restricting its material compatibility. Additionally, the T500’s printing speed is significantly faster, making it ideal for large projects or time-sensitive tasks.
Here’s a quick comparison:
Comgrow T500
CR-M4
500x500x500 mm
400x400x400 mm
Maximum Nozzle Temp
Higher
Standard
Printing Speed
Significantly higher
Limited
Touchscreen
7-inch
Basic
Advanced Features
Yes (e.g., linear rails, direct drive)
Basic (e.g., automatic leveling)
The T500 also includes advanced features like linear rails and a direct drive system, which enhance stability and precision. These features are absent in the CR-M4, making the T500 a more robust and versatile option for professionals and hobbyists alike.
Comgrow T500 vs. Bambu Lab X1C
The Bambu Lab X1C is another competitor, but the T500 offers unique advantages. While the X1C is known for its speed, the T500 balances speed with precision, ensuring high-quality prints even at faster rates. The T500’s large build volume also surpasses the X1C, giving you more room to experiment with larger designs.
The T500’s all-metal hotend and hardened steel nozzle provide greater material compatibility, allowing you to work with abrasive filaments. The X1C lacks this level of durability, making it less suitable for demanding projects. Additionally, the T500’s 7-inch touchscreen and Klipper system simplify the user experience, offering intuitive controls that even beginners can navigate.
Price-to-Performance Ratio of the T500
The Comgrow T500 delivers exceptional value for its price. Its combination of advanced features, large build volume, and high-speed capabilities makes it a cost-effective choice for creators. You get professional-grade performance without the premium price tag of some competitors.
If you’re looking for a 3D printer that balances affordability with top-tier performance, the T500 stands out. Its versatility and user-friendly design ensure that you can tackle a wide range of projects, whether you’re a hobbyist, engineer, or small business owner.
Tip: Consider the T500 if you want a printer that offers both quality and value, making it a smart investment for your creative needs.
Applications and Use Cases
Engineers and Product Designers
The Comgrow T500 is a game-changer for engineers and product designers. Its large build volume allows you to create prototypes and functional parts without size limitations. The high nozzle temperature and material compatibility enable you to work with advanced filaments like carbon fiber and PETG. These materials are ideal for creating durable and heat-resistant components. The printer’s precision ensures that your designs come to life exactly as envisioned. You can also use the T500 to test multiple iterations of a product, saving time and improving efficiency. With its reliable performance, the T500 becomes an essential tool in your design process.
Makers and Hobbyists
If you’re a maker or hobbyist, the T500 opens up endless possibilities for creativity. Its versatility lets you experiment with different materials and nozzle sizes to achieve unique results. Whether you’re crafting decorative items, cosplay props, or functional gadgets, the T500 delivers high-quality prints every time. The large build volume allows you to print multiple items simultaneously, optimizing your workflow. You can also store your projects digitally and access them whenever needed, thanks to the printer’s WiFi connectivity. The T500 makes it easy to turn your ideas into reality, no matter your skill level.
Educational Institutions
The T500 is an excellent addition to classrooms and labs. Its user-friendly interface and automatic leveling system make it accessible for students learning 3D printing. You can use the printer to teach concepts in engineering, design, and manufacturing. The large build volume supports group projects, encouraging collaboration among students. The T500’s ability to handle various materials also allows you to demonstrate real-world applications, from creating prototypes to producing functional parts. With its quiet operation, the printer fits seamlessly into any educational environment. It provides a hands-on learning experience that inspires innovation and problem-solving skills.
Small Businesses and Studios
The Comgrow T500 3D printer offers small businesses and studios a powerful tool to enhance productivity and creativity. Its large build volume of 500mm x 500mm x 500mm allows you to produce multiple items in a single print session. This feature is ideal for batch production, helping you save time and reduce costs. Whether you create prototypes, custom products, or artistic pieces, the T500 ensures consistent quality.
Material versatility is another advantage. The all-metal hotend and hardened steel nozzle let you work with a wide range of filaments, including PLA, PETG, and carbon fiber. This flexibility enables you to meet diverse client needs, from durable functional parts to intricate decorative designs. You can also switch between nozzle sizes to prioritize speed or detail, depending on your project requirements.
Efficient storage of your designs is crucial for small businesses. The T500’s WiFi connectivity allows you to store and manage your projects digitally. You can access your files remotely, start prints from anywhere, and monitor progress in real-time. This feature streamlines your workflow and ensures you stay organized.
The T500’s quiet operation and sleek design make it a great fit for studios or shared workspaces. Its intuitive 7-inch touchscreen simplifies operation, even for those new to 3D printing. Maintenance is straightforward, thanks to its modular design and durable components.
By investing in the Comgrow T500, you equip your business with a reliable and versatile machine. It helps you scale operations, meet client demands, and explore new creative possibilities.
The Comgrow T500 3D printer redefines 3D printing by combining exceptional performance, precision, and usability. Its advanced features, such as the large build volume and dual Z-axis, ensure stability and consistent results. You can rely on its affordability and versatility to meet your creative or professional needs. Positive customer feedback highlights its reliability and ease of use, making it a trusted choice for users of all levels.
Explore More: Visit the official website or contact Comgrow to learn how the Comgrow T500 3D printer can elevate your projects.
What makes the Comgrow T500 suitable for beginners?
The T500’s 7-inch IPS touchscreen and Klipper system simplify operation. Its 49-point automatic bed leveling eliminates manual adjustments, ensuring a smooth start for beginners. You can set it up quickly and focus on printing without worrying about technical complexities.
Tip: Use the touchscreen to explore settings and learn as you go!
Can the T500 handle high-temperature materials?
Yes, the T500’s all-metal hotend reaches up to 300°C. This allows you to print with advanced materials like carbon fiber, PETG, and TPU. The hardened steel nozzle ensures durability, even with abrasive filaments.
Examples
Standard
PLA, ABS, PETG
Advanced
Carbon Fiber, TPU
How does WiFi connectivity improve the printing experience?
WiFi connectivity lets you control and monitor the printer remotely. You can start, pause, or stop prints from your smartphone or computer. This feature saves time and keeps you updated on your project’s progress, even when you’re away.
Is the T500 suitable for professional use?
Absolutely! The T500’s large build volume, high-speed capabilities, and material versatility make it ideal for professionals. Engineers, designers, and small businesses can rely on its precision and durability for prototypes, functional parts, and batch production.
How does the T500 ensure print stability?
The dual Z-axis and Y-axis design, combined with internal linear rails, provide exceptional stability. These features reduce vibrations and ensure smooth movements, resulting in precise and reliable prints.
Note: Stability is crucial for tall or intricate designs. The T500 excels in maintaining alignment throughout the process.
