Method
Contactless
Precision
Durability
Ideal For
Eddy Current
✅ Yes
🚀 Fast
🎯 High
💪 Very High
Large-format/industrial
BLTouch
❌ No
⚙️ Medium
👍 Good
⚠️ Moderate
Desktop printers
Capacitive
✅ Yes
⚙️ Medium
👌 Moderate
⚠️ Sensitive
Smooth non-metal beds
Manual
❌ No
🐢 Slow
🤷♂️ Variable
🧰 N/A
Entry-level users
Whether you're printing:
  • Full-size cosplay props
  • Industrial jigs or fixtures
  • Architectural models
  • Multi-part batch runs
💬 Want to Learn More?
3 must-know SV08 MAX 3D Printer features for 2026
SV08 MAX 3D Printer offers a 500×500×500 mm³ build volume, CoreXY high-speed printing up to 700mm/s, and advanced eddy current bed leveling.
Top 15 Valentine’s Day 3D Printing Gift Ideas to Spark Romance
Impress your loved one with these top 15 Valentine’s Day 3D print ideas—unique, customizable gifts perfect for sparking romance in 2026.
PLA vs PETG: PLA is easier and cheaper for beginners, while PETG offers more strength and heat resistance for durable 3D prints.
