Simple Ways to Use Filament Dryers for Better Prints
Moisture can mess up your 3D printing. It gets into filaments, making them weaker and prints look bad. For example, if filament moisture is over 0.4%, prints have rough surfaces with gaps. After 72 hours in moisture, filament strength drops to 94%. This makes prints weaker. A filament dryer, such as the Sovol SH01 filament dryer or the Sovol SH02 filament dryer, effectively removes this moisture. Drying your filament with a Sovol SH01 filament dryer or a Sovol SH02 filament dryer makes it strong again, improves its appearance, and helps prints turn out better and more accurate.
  • Water ruins 3D print quality. Drying filament makes prints stronger and nicer.
  • Check for moisture signs, like breaking easily or crackling sounds, to know when drying is needed.
  • Use a filament dryer to remove water. This helps make smoother and better prints.
  • Keep filament in sealed boxes with silica gel to stay dry and ready.
  • Check your filament often for water. Weighing it helps you see its condition.
Why Moisture Affects 3D Printing Quality
How Moisture Gets into Filament
Water gets into 3D printing filament in many ways. Most filaments are hygroscopic, meaning they soak up water from the air. This happens faster in places with high humidity. Over time, the water changes the filament, causing printing problems.
Mechanism/Process
Hygroscopic Behavior
Filaments soak up water from the air, raising water levels.
Plasticization
Water makes the filament softer but also weaker.
Swelling
Filament grows bigger as it absorbs water, changing its size.
Matrix Hydrolysis
Water breaks down the filament chemically, making it weaker.
Interfacial Debonding
Water loosens the bond between parts of the filament.
Osmotic Process
Water messes up the filament's inside structure, lowering its quality.
To stop water absorption, keep filaments in a dry place. Filament dryers can also remove water already inside the filament.
Signs Your Filament Needs Drying
Knowing when to dry your filament helps keep prints good. Look for these signs:
  • Brittle Filament: If it breaks easily, it has too much water.
  • Popping or Hissing Sounds: These sounds during printing mean water is escaping.
  • Stringy or Blobby Prints: Too much water causes uneven extrusion, making strings or blobs.
  • Rough or Bubbly Surfaces: Water creates bubbles, making prints rough or uneven.
If you see these signs, drying the filament can fix it and improve prints.
Tip: Check your filament often, especially in humid areas.
Impact of Moisture on Print Quality
Water harms print quality and weakens filament strength. It messes up material flow during printing. This causes bad layer sticking, rough prints, or even cracks. Water also makes the filament less strong and durable.
Drying filament before printing gives better results. Studies show drying loose filament works better than drying it on spools. This removes water faster and improves print looks and strength. Keeping filament dry at all times is key for great prints.
How Filament Dryers Remove Moisture
The Science Behind Filament Drying
Filament dryers use heat and air to take out moisture. Heating makes water inside the filament move and expand. This creates a pressure difference, pushing water out of the filament. Warmer air holds more water, so higher heat dries faster.
Many dryers also use desiccants like silica gel to soak up water. Desiccants work better in cooler places, so check humidity while drying. Weigh the filament spool to track progress. If the weight stays the same, the filament is dry.
Note: Absolute humidity, not relative humidity, affects drying. Temperature changes this, so adjustable dryers give the best results.
Benefits of Using a Filament Dryer
Using a filament dryer helps your 3D printing in many ways:
  • Better Print Quality: Dry filament makes smoother, shinier, and cleaner prints. Problems like bubbles or rough spots are reduced.
  • Steady Results: Drying filament ensures smooth extrusion. This avoids blobs or strings and improves layer sticking.
  • Works with All Materials: Whether using PLA, ABS, or TPU, dryers keep filament strong and reliable.
  • Less Waste: Wet filament causes failed prints. Drying saves time and reduces wasted material.
For example, users say Sovol SH01 and Sovol SH02 dryers improve print quality and strength. These dryers remove moisture well, making prints look professional and last longer.
Types of Filament Dryers to Consider
Pick a filament dryer based on your needs. Here’s a comparison of popular ones:
Filament Dryer
Drying Method
Performance Characteristics
FilaDryer S2
Active
Holds 1 spool, adjustable settings
Great for common materials
FilaDryer S4
Active
Holds 4 spools, strong heating
Dries faster than S2
D1 Filament Dryer
Active
Heats all around, can be wall-mounted
Lowers filament breaking risk
PrintDry Pro3
Active
Heats up to 85 °C, six preset options
Works for many materials
Drywise Filament Dryer
Active, Desiccant
Dries engineering filaments inline, updated material list
Good for industrial use
FD1 Filament Dryer
Active
Dries, conditions, and feeds filament
Works with many materials
For hobbyists, the Sovol SH01 filament dryer (available here) is great for one spool. If you need to dry more spools at once, try the Sovol SH02 filament dryer (available here) for faster drying and advanced features.
Best Practices for Filament Drying
Getting Filament Ready for Drying
Check your filament for signs of water damage. Look for brittleness or bubbles. Clean off any dust or dirt before drying. If the filament is on a spool, loosen it a bit for better airflow. For loose filament, spread it out evenly on a tray.
Here’s a simple guide for drying different filaments:
Best Drying Temperature (°C)
Suggested Drying Time
40–50
4–6 hours
60–70
4–6 hours
70–80
8–12 hours
70–90
Overnight
40–50
4–6 hours
Tip: Always follow the manufacturer’s drying instructions for best results.
Choosing the Right Temperature and Time
Using the right heat and time is important. This removes water without harming the filament. For example, drying nylon at 85°C overnight works well. A food dehydrator is good for PLA and PETG but may not work for tougher materials like nylon.
Steps to dry filament properly:
  1. Set the dryer to the correct temperature for your filament.
  2. Watch the process to prevent overheating.
  3. Weigh the filament before and after drying. If the weight stays the same, it’s dry.
If you use desiccants, dry them in an oven at 110°C for two hours when they’re full of moisture.
Drying Tips for Different Filaments
Each filament type needs special care. PLA and TPU need lower heat, while ABS and nylon need higher temperatures. Nylon absorbs water fast, so drying it overnight is often needed. For TPU, don’t use too much heat to avoid damage.
Pro Tip: After drying, store filament in vacuum-sealed bags with desiccants to keep it dry.
By following these tips, your filament will stay dry and ready for great prints.
Maintaining Filament Quality After Drying
Storing Filament the Right Way
Keep your 3D filament in a dry, safe place. Filaments soak up water from the air, which can ruin prints. Wet filament causes rough surfaces and weak prints. Use airtight containers to stop moisture from getting in.
Vacuum-sealed bags are also a great choice. They are cheap, come in many sizes, and block water from reaching the filament. Add silica gel packets to these bags to absorb extra moisture. This keeps your filament dry and ready to use.
Tip: Write the filament type and drying date on the container. This helps you track its condition easily.
Using Silica Gel and Vacuum Bags
Silica gel packets are great for keeping filament dry. These packets soak up water and keep the storage space moisture-free. Put them in airtight containers or vacuum-sealed bags with your filament.
Vacuum-sealed bags give extra protection. They remove air, lowering the chance of water getting in. This simple method works well to keep filament in good shape.
Using both silica gel and vacuum bags keeps filament dry. This avoids problems like popping sounds or uneven printing.
Checking Filament for Moisture
Check your filament often to spot problems early. Look for brittleness, bubbles, or mold. These signs mean the filament has absorbed water and needs fixing.
Filaments pull in water from the air, which causes issues. Wet filament can make popping noises, stringy prints, or weak results. Regular checks help you fix these problems before printing.
Pro Tip: Weigh your filament spool now and then. If it’s heavier, it may have absorbed water. Dry it again to fix this.
Follow these steps to keep your filament in top shape and get better prints every time.
Water can mess up your 3D printing, but filament dryers fix this. Using the right drying methods and tools makes prints better and filaments last longer. Keeping filament dry after drying helps it stay in great shape. These easy steps give you smoother, stronger, and more accurate prints. Try these tips now to improve your 3D printing results.
Pro Tip: Always dry and store filament properly for better, lasting prints.
How should you store filament after drying?
Keep it in a sealed container with silica gel packs. Vacuum-sealed bags are also a good option. These stop water from getting back into the filament, keeping it dry and ready to use.
When should you dry your filament?
Dry it if you see signs of moisture, like brittleness or popping sounds while printing. In humid places, check and dry it more often to keep prints looking good.
Can a food dehydrator dry filament?
Yes, you can use a food dehydrator for some filaments like PLA or PETG. But it might not get hot enough for materials like nylon. Always check the drying temperature for your filament type.
Does drying filament make prints stronger?
Yes, drying removes water that makes filament weak. This makes prints stronger and last longer. Dry filament also helps layers stick better and gives smoother results.
Why does filament soak up water?
Most 3D printing filaments absorb water because they are hygroscopic. This happens faster in wet air. Storing and drying them properly stops water problems.
Best Budget 3D Printer for Beginners of 2025
Looking for the best beginner 3D printer in 2025? See top budget picks with easy setup, smart features, and reliable results for first-time users.
Advanced modeling for large-scale 3D printing: techniques from design to execution
Advanced modeling for large-scale 3D printing streamlines design, boosts part strength, and ensures precision from digital workflow to final execution.
SV08 MaxDiscover How Sovol SV08 Max Transforms Your Printing Experience
Sovol SV08 Max delivers large-scale 3D printing, rapid speeds, and precise results, enhancing creativity, efficiency, and reliability for all your projects.
