2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
Ultimate Tutorial for Creating Custom RC Cars Using 3D Car Customizer Tools and Sovol Filament
Design your dream RC car with 3D car customizer tools and Sovol filament. Step-by-step guide covers modeling, printing, and assembly for unique results.
Sovol SV08 Max 3D Printer Key Specs and Benefits
SV08 MAX offers a 500×500×500 mm build area, up to 700 mm/s speed, CoreXY motion, linear rails, and smart feeder for fast, reliable 3D printing.
How Print Speed Compares Between FDM and Resin 3D Printers
Wondering which is faster fdm or resin? Resin printers excel at small, detailed prints, while FDM is quicker for large, simple models.
