2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
How SV08 Max Enclosure Kit Solves Common 3D Printing Temperature Fluctuations
SV08 Max Enclosure Kit maintains stable temperatures, reducing warping and layer splits for stronger, higher-quality 3D prints with advanced materials.
Understanding the Differences Between Sovol SH02 and SH03 Filament Dryers
Sovol SH02 vs SH03 filament dryer: Compare drying capacity, temperature range, and features to choose the best Sovol filament dryer for your 3D printing setup.
SH03 Filament DryerWhy Sovol Filament Dryer 4 Spools Is the Secret Ingredient for Smooth Prints
Sovol Filament Dryer 4 Spools keeps filament dry, prevents moisture issues, and ensures smooth, strong 3D prints for multi-material projects.
