2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
Sovol SV08 Max vs Creality K1 Max Printer Comparison
Compare the Sovol SV08 Max and Creality K1 Max to find the best large-format 3D printer for speed, accuracy, and affordability in 2025.
How Sovol SV08 Max Makes Large-Scale Printing Faster and Easier
The Sovol SV08 Max speeds up large-scale 3D printing with 700 mm/s capability, 500×500×500 mm build volume, and smart features for precision and ease.
Sovol SV08 Max High-Speed Printing and Precision Unveiled
The Sovol SV08 Max offers 450 mm/s high-speed printing with CoreXY precision, a 500×500×500 mm build space, and advanced features for smooth, accurate results.
