2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
PETG Filament: The Perfect Balance Between Strength and Ease of Printing
PETG filament offers a perfect mix of strength, durability, and ease of printing. It resists warping, adheres well, and is ideal for functional 3D prints.
Voron vs. Sovol vs. Prusa: Which Open Source Printer Fits You Best?
Compare Voron, Sovol, and Prusa to find the best Open Source 3D Printer for your needs. Discover options for beginners, hobbyists, and advanced users.
Why closed source 3D printer systems are rising
Closed-source 3D printer systems are rising due to better quality control, IP protection, and ease of use, but they limit customization and increase costs.
