2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
COREXY printer SV08 makes big projects simple and fun
COREXY printer SV08 offers fast setup, large build volume, and high-speed precision, making big 3D printing projects simple, efficient, and fun.
3D Printing Made Easy: Why Quick-Assembly Kits Are Perfect for Newbies
Quick-Assembly 3D printing kits offer easy setup, minimal tools, and strong support, making them ideal for beginners starting their 3D printing journey.
Advantages of PETG filament compared to PLA
Advantages of PETG include superior impact resistance, flexibility, and durability over PLA, making it ideal for functional and outdoor 3D printed parts.
