2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
Step-by-Step Guide to Building a Voron 3D Printer in 2025
Build your own Voron 3D printer in 2025 with this step-by-step guide. Learn about tools, components, assembly, and tips for optimal performance.
Three Business Models for 3D Printed Architecture
Discover how 3D Printed Architecture in 2025 is revolutionizing construction with advanced materials, AI, robotics, and sustainable practices.
PETG Filament: The Perfect Balance Between Strength and Ease of Printing
PETG filament offers a perfect mix of strength, durability, and ease of printing. It resists warping, adheres well, and is ideal for functional 3D prints.
