2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
3 must-know SV08 MAX 3D Printer features for 2026
SV08 MAX 3D Printer offers a 500×500×500 mm³ build volume, CoreXY high-speed printing up to 700mm/s, and advanced eddy current bed leveling.
Top 15 Valentine’s Day 3D Printing Gift Ideas to Spark Romance
Impress your loved one with these top 15 Valentine’s Day 3D print ideas—unique, customizable gifts perfect for sparking romance in 2026.
PLA vs PETG: PLA is easier and cheaper for beginners, while PETG offers more strength and heat resistance for durable 3D prints.
