2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
Voron vs. Sovol vs. Prusa: Which Open Source Printer Fits You Best?
Compare Voron, Sovol, and Prusa to find the best Open Source 3D Printer for your needs. Discover options for beginners, hobbyists, and advanced users.
Why closed source 3D printer systems are rising
Closed-source 3D printer systems are rising due to better quality control, IP protection, and ease of use, but they limit customization and increase costs.
Tips for Spotting Good vs Bad 3D Filaments
Learn how to perform a 3D printing filament quality check to spot good filaments. Ensure smooth prints by checking diameter, material purity, and packaging.
