2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
What is ABS filament Uses and Key Properties Explained
What is ABS filament? ABS filament is a tough, heat-resistant 3D printing material used for durable parts and prototypes in various industries.
Step-by-step 3d printer lubrication guide anyone can follow
Follow this 3d printer lubrication guide for easy steps to clean, lubricate, and maintain your printer for smoother prints and longer machine life.
How to maintain hotend for beginners with simple steps
Follow this step-by-step guide on how to maintain hotend for beginners to prevent clogs, improve print quality, and keep your 3D printer running smoothly.
