2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
Improve 3D printing bed adhesion with 7 proven tips like leveling the bed, adjusting nozzle height, cleaning surfaces, and optimizing print settings.
