- Contactless measurement: No risk of probe drag or mechanical wear.
- High speed: Can scan a 500mm bed in ~80 seconds.
- Thermal resistance: Not affected by heated beds like some capacitive sensors.
- Exceptional repeatability: Ensures your first layer sticks every time, even after long prints.
Method |
Contactless |
Speed |
Precision |
Durability |
Ideal For |
Eddy Current |
✅ Yes |
🚀 Fast |
🎯 High |
💪 Very High |
Large-format/industrial |
BLTouch |
❌ No |
⚙️ Medium |
👍 Good |
⚠️ Moderate |
Desktop printers |
Capacitive |
✅ Yes |
⚙️ Medium |
👌 Moderate |
⚠️ Sensitive |
Smooth non-metal beds |
Manual |
❌ No |
🐢 Slow |
🤷♂️ Variable |
🧰 N/A |
Entry-level users |
Whether you're printing:
- Full-size cosplay props
- Industrial jigs or fixtures
- Architectural models
- Multi-part batch runs
Sovol SV08 Max: Built-In Precision
💬 Want to Learn More?
- Explore the Sovol SV08 Max
- Learn about Klipper’s integration with Eddy Current sensors
- Join the Sovol user community on Facebook
