Method
Contactless
Precision
Durability
Ideal For
Eddy Current
✅ Yes
🚀 Fast
🎯 High
💪 Very High
Large-format/industrial
BLTouch
❌ No
⚙️ Medium
👍 Good
⚠️ Moderate
Desktop printers
Capacitive
✅ Yes
⚙️ Medium
👌 Moderate
⚠️ Sensitive
Smooth non-metal beds
Manual
❌ No
🐢 Slow
🤷♂️ Variable
🧰 N/A
Entry-level users
Whether you're printing:
  • Full-size cosplay props
  • Industrial jigs or fixtures
  • Architectural models
  • Multi-part batch runs
💬 Want to Learn More?
sovol sv08 max
Choose the right large 3D printer by matching build volume, materials, and features to your project needs, workspace, and budget for optimal results.
Why Sovol Zero 3D Printer Is Ideal for Fast Prototyping and Small Parts
Sovol Zero 3D printer offers unmatched speed, precision, and reliability, making it perfect for fast prototyping and small parts with advanced features.
Sovol Zero 3D Printer Delivers Unmatched Speed and Precision
Sovol Zero 3D Printer achieves unmatched speed and precision with CoreXY motion, linear rails, and advanced input shaping for rapid, flawless prints.
