Method
Contactless
Precision
Durability
Ideal For
Eddy Current
✅ Yes
🚀 Fast
🎯 High
💪 Very High
Large-format/industrial
BLTouch
❌ No
⚙️ Medium
👍 Good
⚠️ Moderate
Desktop printers
Capacitive
✅ Yes
⚙️ Medium
👌 Moderate
⚠️ Sensitive
Smooth non-metal beds
Manual
❌ No
🐢 Slow
🤷♂️ Variable
🧰 N/A
Entry-level users
Whether you're printing:
  • Full-size cosplay props
  • Industrial jigs or fixtures
  • Architectural models
  • Multi-part batch runs
💬 Want to Learn More?
Top Free 3D Printing Software for Beginners Who Want to Start Fast
Wondering what software to use for 3D printing? Try free tools like Tinkercad, Cura, and PrusaSlicer for fast, beginner-friendly 3D printing success.
Why Sovol SV08 3D Printer Is the Top Choice for Fast and Accurate Printing
Sovol SV08 3D Printer delivers fast, accurate prints with CoreXY motion, large build volume, and open-source flexibility for all your 3D printing needs.
All You Need to Know About Extruder Machines in FDM 3D Printing
Extruder machines in FDM 3D printing feed, melt, and deposit filament, ensuring precise layer formation and reliable print quality for various materials.
