2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
Recommended 3D Printing Temperature Settings for PLA, PETG, ABS, and TPU
Find the best 3D printing temperature settings for PLA, PETG, ABS, and TPU to improve print quality, layer adhesion, and reduce warping.
Why Moisture Ruins 3D Prints
Wet filament causes weak, rough, and brittle 3D prints. Prevent moisture damage by storing and drying filament before printing.
How to Fix Inconsistent Extrusion in 3D Printing
Fix inconsistent extrusion 3D printing by checking filament, cleaning the nozzle, calibrating extruder, and adjusting slicer settings for smooth prints.
