2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
3 reasons SV08 MAX enclosure boosts print quality
SV08 MAX enclosure ensures stable temperature, blocks dust, and reduces noise, delivering higher print quality and reliability for large-format 3D printing.
3D Printer Clicking or Skipping Steps Causes and Fixes
3D printer clicking often signals nozzle clogs, feed issues, or tension problems. Find causes and fixes to stop clicking and improve print quality.
How to Fix Stringing in 3D Printing
Fix 3D printing stringing by adjusting retraction, lowering print temperature, and drying filament for cleaner, string-free prints every time.
