With the Sovol SV06 ACE 3D printer, you get outstanding value and advanced features. The Sovol SV06 ACE stands out with its auto leveling, rapid printing speeds, and robust frame, ensuring your prints are accurate and reliable. Enjoy time-saving fast 3D printing and a straightforward setup process. Many users appreciate the Sovol SV06 ACE for its auto leveling and integrated Klipper firmware.
- Prints fast
- Delivers high-quality prints
- Offers a spacious build volume
- Features automatic leveling
- Priced affordably
Aspect |
Sovol SV06 ACE |
Other 3D Printers |
Max Printing Speed |
600 mm/s |
250-300 mm/s |
Build Volume |
220×220×250 mm |
220×220×250 mm |
Key Features |
Auto leveling, Klipper, touchscreen |
Fewer features |
User Feedback |
High print quality, easy setup |
Fewer features |
With the Sovol SV06 ACE, you benefit from stable 3D prints, effortless leveling, and powerful Klipper performance every time you print.
- The Sovol SV06 ACE prints fast and well. It can print up to 600 mm/s. The frame is strong and steady. This helps make prints more accurate.
- Its auto leveling system checks 25 spots on the bed. This makes setup simple. You do not need to adjust it by hand. The first layers come out perfect.
- Klipper firmware makes printing faster and better. You can control it from far away. You can also change settings easily with a simple screen.
- The dual gear extruder feeds filament smoothly. It works well with flexible materials. This helps stop print problems.
- The touchscreen is easy to use. There are many ways to connect, like remote access. You can get updates over the air. Printing is simple and easy.
Sovol SV06 ACE Features
The Sovol SV06 ACE has many helpful features. These features make 3d printing easier and faster. The printer uses smart technology and a good design. You can make high-quality prints and save time. The Sovol SV06 ACE gives you a smooth and simple experience.
Klipper Firmware
Klipper firmware makes the Sovol SV06 ACE better. It helps your printer work faster and print better. Klipper uses another processor to do hard math. This lets the printer move quickly and smoothly. Standard firmware is not as fast or smooth.
Klipper Firmware Benefits |
Standard Firmware Limitations |
Processing Architecture |
High stepping rates, smooth motion |
Limited speed and precision |
Input Shaping |
Reduces vibrations, better print quality |
More print defects like ghosting |
Pressure Advance |
Controls extrusion, less oozing, better adhesion |
Harder to adjust, less control |
Configuration |
Easy text file edits, no need to recompile |
Needs technical skills to change settings |
Remote Access |
Web interfaces for real-time monitoring and control |
Limited or no remote features |
You can use web tools like Mainsail or Fluidd. These let you check your print from your computer or phone. You can change settings and watch your print. Klipper also has input shaping and pressure advance. These help you get cleaner prints at high speeds. You do not need to be an expert to change settings. You just edit a simple text file.
Tip: Klipper firmware keeps your Sovol SV06 ACE updated. There is a strong community to help you.
Auto Leveling
Leveling is easy with the Sovol SV06 ACE. The printer has an auto leveling system. You do not need to adjust it by hand. It uses 25 points to scan the print bed. This makes a map of the surface. The printer changes the nozzle height for perfect first layers.
- Dual Z-axis motors help the system work well.
- Thick Z-axis rods and a strong frame keep it steady.
- Auto leveling saves time and stops mistakes.
- You get good prints even if the bed is not flat.
- Both beginners and experts can use this system.
You can use one-click self-check to start leveling. The printer does the rest for you. The system changes the nozzle height while printing. This stops problems like uneven layers.
Note: Clean the nozzle, check the belts, and heat the bed before leveling.
Dual Gear Extruder
The Sovol SV06 ACE has a dual gear extruder. It uses a 1:7.5 gear ratio. This gives a strong grip on the filament. You get smooth extrusion, even with flexible materials.
Single Gear Extruder |
Dual Gear Extruder (SV06 ACE) |
Filament Grip |
Less grip, more slippage |
Strong grip, less slippage |
Extrusion Control |
Less accurate |
More accurate and responsive |
Flexible Filament |
Can buckle or jam |
Handles flexible filament easily |
Retraction Settings |
Longer, less precise |
Shorter, more precise |
Print Quality |
More stringing, less detail |
Smoother surfaces, better corners |
You can print with PLA, PETG, TPU, and ABS (with enclosure). The dual gear extruder stops under-extrusion and stringing. You get better prints and more reliable results.
High-Speed Printing
The Sovol SV06 ACE prints very fast. It can print up to 600 mm/s. Acceleration can reach 20,000 mm/s². This is much faster than most other printers. You can finish a Benchy print in under 13 minutes.
- The strong frame keeps the printer steady at high speeds.
- A powerful fan cools your prints quickly.
- Klipper firmware helps keep prints looking good, even when printing fast.
You save time on every project. You can print more models in less time. This makes the Sovol SV06 ACE great for quick projects.
Touchscreen & Connectivity
The Sovol SV06 ACE has a 4.3-inch touchscreen. The screen is easy to use. You can start prints and change settings with a few taps.
The Sovol SV06 ACE has many ways to connect:
- USB lets you print from a flash drive.
- You can use the Obico app to watch your prints on your phone.
- You can update the firmware over the air with one click.
- The printer is open-source, so you can customize it.
You can use remote access to watch and control your prints. You can even make time-lapse videos. The camera and remote features let you manage your printer from anywhere. This is great for busy people who want flexibility.
Note: The Sovol SV06 ACE’s remote features help you control your printer at home or away.
Main Features at a Glance
- Klipper firmware gives you fast, high-quality prints and remote access.
- Auto leveling uses 25 points for perfect first layers.
- Dual gear extruder helps with reliable filament feeding and print quality.
- High-speed printing up to 600 mm/s saves time.
- 4.3-inch touchscreen makes operation easy.
- Many ways to connect, like USB and the Obico app.
- OTA updates and open-source platform let you improve and customize.
The Sovol SV06 ACE is a great value 3d printer. You get smart features, fast speeds, and easy remote access. You can start your next project with confidence.
Print Quality and Consistency
Structural Upgrades
You want your prints to look neat and professional. The Sovol SV06 ACE helps with its strong frame and smart design. It uses thick Z-axis rods and two Z motors. These parts keep the printer steady when it moves. This means less shaking and more accurate prints. The leveling system works with these upgrades to keep the bed flat. You get high-quality prints every time. The sturdy frame and dual motors help auto leveling work well. You do not need to worry about uneven or wobbly prints.
All-Metal Hotend
The Sovol SV06 ACE has an all-metal hotend that heats up to 300°C. This lets you print with many types of filament. You can use PLA, PETG, TPU, and ABS (with enclosure). The direct drive and bi-metal heat break give better control over the filament. You get smooth, high-quality prints, even with flexible or hot materials. The table below shows how the hotend helps you:
Benefit |
All-metal direct drive |
Prints flexible and high-temp materials |
Bi-metal heat break |
Handles up to 300°C for more options |
Dual gear system |
Steady extrusion and better filament control |
You can trust this printer to give good results on every project. The leveling system and hotend work together to make prints better and more consistent.
Cooling System
A good cooling system is important for great prints. The Sovol SV06 ACE uses a 4020 high-speed ball bearing fan. This fan cools your prints quickly. You get less warping and better layers. The cooling system also helps with small details and tricky shapes. Here are some ways the cooling system helps your prints:
- The fan gives strong airflow for fast cooling.
- You get smoother surfaces and sharper corners.
- Cleaning the fan and vents keeps the system working well.
- The Z-hop lifts the nozzle to protect small parts.
You see better print quality, especially on hard models. The cooling and leveling systems make sure your prints look good from start to finish.
Intelligent Algorithms
The Sovol SV06 ACE uses smart algorithms to make prints better. Pressure advance stops oozing and makes corners sharp. Resonance compensation checks nozzle pressure for smooth surfaces. These features work with auto leveling to give you great prints every time.
- Pressure advance gives cleaner prints and sharp corners.
- Resonance compensation makes the surface of your prints smooth.
- You get fewer mistakes and more even results.
You can count on the Sovol SV06 ACE for top print quality and consistency. The smart features, strong frame, and good cooling all work together for the best results.
Value Comparison
Sovol SV06 ACE vs. Previous Models
When you pick the Sovol SV06 ACE, you get a big upgrade. Older Sovol 3d printers do not have as many features. The table below shows the differences:
Feature/Aspect |
Sovol SV06 ACE |
Previous Sovol Models / Competitors |
Auto Leveling |
Advanced 25-point auto leveling system with adaptive probing, fully automatic |
Basic or manual leveling, less precise |
Z-Axis Stability |
Dual Z-axis motors, thicker rods, reinforced frame for reduced shaking |
Single Z-axis or less reinforced, more wobble |
Extruder |
All-metal direct drive extruder with bi-metal heat break for flexible and high-temp filaments |
Less advanced extruder, limited filament control |
Up to 600 mm/s supported by Klipper firmware for high speed and quality |
Typically 250-300 mm/s, slower firmware |
Build Volume |
220×220×250 mm |
Smaller typical volumes (e.g., 220×220×250 mm) |
Additional Features |
Built-in camera, resonance sensors, open-source design, powerful cooling fan |
Fewer or no such advanced features |
User Experience |
Easy setup (~15 minutes), beginner-friendly, reliable results |
More complex setup, less beginner-friendly |
The Sovol SV06 ACE gives you better leveling and more stability. It prints faster than older models. You also get extra features for less money.
Sovol SV06 ACE vs. Competitors
Other 3d printers in this price range are slower. They do not have as many features as the Sovol SV06 ACE. This printer can print up to 600 mm/s. Most other printers only go 250-300 mm/s. The auto leveling system helps you get perfect first layers. You also get a built-in camera and a strong cooling fan. The touchscreen makes it easy to use. People say the print quality is great, with smooth layers and sharp details. The Sovol SV06 ACE is good for beginners and experts.
Tip: The Sovol SV06 ACE’s auto leveling and strong frame help you get good prints, even on hard projects.
Price and Performance
You want a 3d printer that gives you the best deal. The Sovol SV06 ACE has top features for a lower price than most other printers. Look at this comparison:
Feature/Aspect |
Sovol SV06 ACE 3D Printer |
Other Popular Models |
Up to 600 mm/s |
250-300 mm/s |
Build Volume |
220×220×250 mm |
Typically 220×220×250 mm |
Key Features |
Auto leveling, dual Z-axis, planetary extruder, Klipper firmware, camera, touchscreen |
Basic auto leveling, slower speeds, fewer features |
Customer Reviews |
Excellent print quality, great results, easy setup |
Good quality, but fewer features |
You save money and get more features with the Sovol SV06 ACE. The fast speed, leveling, and print quality make it a smart pick. If you want to improve your 3d printing, now is a good time to check out the Sovol SV06 ACE.
User Experience & Tips
Setup and Assembly
You will find the Sovol SV06 ACE offers easy setup. The printer arrives almost fully assembled. You only need to attach a few parts, like the touchscreen and spool holder. Most users finish assembly in about 15 minutes. You do not need special tools or skills. The process feels almost plug-and-play. You can start 3d printing quickly without stress.
- Attach the touchscreen and spool holder.
- Plug in the cables.
- Power on the printer.
- Use the auto leveling feature to level the print bed.
The auto leveling system uses 25 points to scan the bed. You do not need to adjust the bed by hand. This makes the Sovol SV06 ACE much easier to set up than many other 3d printers. The dual Z-axis motors and reinforced rods add stability but do not make setup harder. You get a stable printer with less effort.
Tip: Always use the auto leveling function before your first print. This step ensures your prints stick well and look sharp.
Everyday Printing
You can achieve high-quality prints every day with the Sovol SV06 ACE. The advanced auto leveling system keeps your first layer perfect. The printer uses a strong frame and dual Z motors for smooth movement. You get even layers, even at high speeds.
Here are some tips for maximizing print quality:
- Clean the print bed and nozzle after each print.
- Check and tighten belts weekly.
- Lubricate moving parts monthly.
- Store filament in dry containers.
- Adjust nozzle height with a piece of paper for the best first layer.
- Set the right temperature for your filament.
- Slow down the first layer speed for better adhesion.
- Use the touchscreen for quick adjustments.
- Try remote access to monitor your prints from anywhere.
You can use the Sovol SV06 ACE for rapid prototyping, functional parts, and multi-material prints. The auto leveling and remote access features help you print with confidence.
Note: Remote access lets you watch your prints and make changes, even if you are not near the printer.
Troubleshooting
If you want to keep your 3d prints looking great, follow these troubleshooting steps:
- If prints do not stick, run the auto leveling again and check the bed surface.
- If you see uneven layers, check the dual Z motors and rods for stability.
- For clogs, clean the nozzle and replace it if needed.
- If you notice stringing, adjust the klipper pressure advance settings.
- Use remote access to pause or stop prints if you spot problems.
The Sovol SV06 ACE makes troubleshooting simple. The touchscreen and remote access features help you fix issues fast. You can also update firmware easily for better performance.
Tip: Improving auto leveling and calibrating your printer regularly will help you get the best results.
You want a 3D printer that is easy to use. The sovol sv06 ace prints fast and has a strong frame. It gives you a big space to make your projects. The auto leveling system checks 25 spots on the bed. This helps your first layer come out just right. You do not have to level the bed by hand. The printer checks the bed before each print. This means your prints look smooth every time. Auto leveling saves you time and work. You can use many types of materials with this printer. Setting it up is simple and quick. People like the sovol sv06 ace for its auto leveling and good print quality. Look for deals and start your next project with this great 3D printer.
How does the Sovol SV06 ACE’s auto leveling system work?
The Sovol SV06 ACE checks 25 spots on the print bed. It scans the bed before every print. The printer changes the nozzle height by itself. You do not need to level the bed by hand. This system helps you get good prints and saves time.
Can I use remote access and control my Sovol SV06 ACE from anywhere?
Yes, you can use remote access with a mobile app. The app works on iOS and Android phones. You can watch your prints, pause, or stop them. The built-in camera lets you see your print from anywhere. Remote control makes 3d printing easier for you.
What materials can I print with on the Sovol SV06 ACE?
You can print with PLA, PETG, TPU, and ABS if you use an enclosure. The all-metal hotend and dual gear extruder help your prints look better. You get good results with many types of filament.
How does the Sovol SV06 ACE improve print quality and consistency?
The Sovol SV06 ACE has a strong frame and two Z motors. It also has a good cooling system. The printer uses smart features like pressure advance and resonance compensation. These help you get smooth and high-quality prints every time.
Is the Sovol SV06 ACE easy to set up for beginners?
The Sovol SV06 ACE is easy to set up. Most people finish putting it together in about 15 minutes. The auto leveling and touchscreen help you start your first print fast. Even beginners can use this printer without trouble.
