Method
Contactless
Precision
Durability
Ideal For
Eddy Current
✅ Yes
🚀 Fast
🎯 High
💪 Very High
Large-format/industrial
BLTouch
❌ No
⚙️ Medium
👍 Good
⚠️ Moderate
Desktop printers
Capacitive
✅ Yes
⚙️ Medium
👌 Moderate
⚠️ Sensitive
Smooth non-metal beds
Manual
❌ No
🐢 Slow
🤷♂️ Variable
🧰 N/A
Entry-level users
Whether you're printing:
  • Full-size cosplay props
  • Industrial jigs or fixtures
  • Architectural models
  • Multi-part batch runs
💬 Want to Learn More?
How to Tell If Your Filament Is Wet During Printing
Spot wet filament symptoms like popping sounds, bubbles, stringing, and weak layers during 3D printing to avoid poor print quality and wasted material.
SH03 Filament DryerHow to Fix Filament Popping During 3D Printing
Stop filament popping during 3D printing by drying filament, adjusting temperature, and cleaning the nozzle for smoother, stronger prints.
SH03 Filament DryerWhat Makes Sovol SH03 Dryer Stand Out for 3D Printing Filament Care
Sovol SH03 Dryer offers dual chambers, fast heating, and auto dehumidification for efficient, quiet 3D printing filament care and consistent print quality.
