Method
Contactless
Precision
Durability
Ideal For
Eddy Current
✅ Yes
🚀 Fast
🎯 High
💪 Very High
Large-format/industrial
BLTouch
❌ No
⚙️ Medium
👍 Good
⚠️ Moderate
Desktop printers
Capacitive
✅ Yes
⚙️ Medium
👌 Moderate
⚠️ Sensitive
Smooth non-metal beds
Manual
❌ No
🐢 Slow
🤷♂️ Variable
🧰 N/A
Entry-level users
Whether you're printing:
  • Full-size cosplay props
  • Industrial jigs or fixtures
  • Architectural models
  • Multi-part batch runs
💬 Want to Learn More?
PLA vs PETG: PLA is easier and cheaper for beginners, while PETG offers more strength and heat resistance for durable 3D prints.
How the Sovol SH02 Dryer Eliminates Filament Moisture for Flawless 3D Prints
Sovol SH02 Dryer eliminates filament moisture, reducing stringing and bubbles for flawless 3D prints with stronger layers and fewer failures.
Why is my 3D print stringing even with dry filament
3D print stringing can occur with dry filament due to incorrect retraction, nozzle temperature, or travel speed settings. Adjust these to reduce stringing.
