Method
Contactless
Precision
Durability
Ideal For
Eddy Current
✅ Yes
🚀 Fast
🎯 High
💪 Very High
Large-format/industrial
BLTouch
❌ No
⚙️ Medium
👍 Good
⚠️ Moderate
Desktop printers
Capacitive
✅ Yes
⚙️ Medium
👌 Moderate
⚠️ Sensitive
Smooth non-metal beds
Manual
❌ No
🐢 Slow
🤷♂️ Variable
🧰 N/A
Entry-level users
Whether you're printing:
  • Full-size cosplay props
  • Industrial jigs or fixtures
  • Architectural models
  • Multi-part batch runs
💬 Want to Learn More?
How to Manually Level a 3D Printer Bed for Beginners
Manually level your 3D printer bed with simple tools for better 3D printer bed leveling, improved first layer adhesion, and fewer print failures.
How to Fix 3D Printer First Layer Not Sticking Issues Easily
Solve 3D printer first layer not sticking by cleaning the bed, adjusting temperatures, leveling, and using adhesion aids for strong, reliable prints.
How to Fix 3D Printer Layer Shifting Step by Step
Fix 3D printer layer shifting by checking belts, pulleys, motors, and slicer settings. Follow these steps to solve misaligned layers and improve print quality.
