2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
PLA vs PETG: PLA is easier and cheaper for beginners, while PETG offers more strength and heat resistance for durable 3D prints.
How the Sovol SH02 Dryer Eliminates Filament Moisture for Flawless 3D Prints
Sovol SH02 Dryer eliminates filament moisture, reducing stringing and bubbles for flawless 3D prints with stronger layers and fewer failures.
Why is my 3D print stringing even with dry filament
3D print stringing can occur with dry filament due to incorrect retraction, nozzle temperature, or travel speed settings. Adjust these to reduce stringing.
