2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
The Ultimate Guide to Nozzle Temperature for 3D Printing Materials in 2026
3D print nozzle temperature guide for 2026: Find optimal settings for PLA, ABS, PETG, and more to boost print quality and prevent common printing issues.
How Many Top Layers Should You Use in 3D Printing for Smooth Results
Use 3 to 5 3D print top layers for smooth, strong surfaces. Adjust layer height and infill for best results and avoid gaps or rough finishes.
When Should You Upgrade Your 3D Printer Instead of Changing Settings?
Decide when to fix vs upgrade 3d printer: If settings don't solve print issues, hardware limits may mean it's time for an upgrade or replacement.
