2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
SH03 Filament DryerAvoiding 3D Printing Failures Caused by Wet Filament with the SH03 Filament Dryer
SH03 Filament Dryer removes moisture from filament, preventing weak prints, stringing, and surface defects for reliable 3D printing results.
Why Enclosures Matter for Large-Format 3D Printing
A 3D printer enclosure ensures stable temperature, reduces warping, controls fumes, and protects large-format 3D printers for better results.
How SV08 Max Enclosure Kit Solves Common 3D Printing Temperature Fluctuations
SV08 Max Enclosure Kit maintains stable temperatures, reducing warping and layer splits for stronger, higher-quality 3D prints with advanced materials.
