2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
How to Fix High Speed 3D Printing Problems in 2026
Solve high speed 3D printing problems with tips for bed adhesion, extrusion, and surface defects. Get reliable, high-quality prints every time in 2026.
Essential Tips to Reduce Printing Costs for Large Format 3D Printing
Cut costs with large format 3D printing tips on materials, print settings, and design strategies for efficient, high-quality large-scale prints.
How to Prevent Large 3D Print Failures with Proven Techniques
Stop large print failure causes in 3D printing by fixing bed adhesion, extrusion, and mechanical issues for reliable big print results.
