2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
Understanding the Differences Between Over Extrusion and Under Extrusion in 3D Printing
Over extrusion vs under extrusion 3D printing: Compare causes, symptoms, and effects to improve print quality and avoid common filament issues.
Z seam in 3D printing explained for beginners
A Z seam in 3D printing is a visible line where each layer starts and ends. It occurs due to nozzle movement and extrusion changes during printing.
Why Small Parts Fail in 3D Printing and Easy Fixes
Why small parts fail in 3D printing: causes like poor adhesion, warping, and easy fixes to improve print quality and prevent common small part failures.
