2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
CoreXY vs Bedslinger: Differences + Buying Checklist
Learn CoreXY vs bedslinger differences and use a simple checklist to choose the right 3D printer motion system for your prints.
PLA Not Sticking to Bed? Fix First-Layer Adhesion Fast
Step-by-step fixes for PLA bed adhesion—cleaning, levelling, Z-offset, and first-layer settings—plus quick checks for beginners.
Best Large Format 3D Printer for Schools & Makerspaces
A practical 500mm-class buyer’s guide for UK school labs and makerspaces: safety, ventilation, reliability, and what to check before you buy.
