2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
How to Tell If Your Filament Is Wet During Printing
Spot wet filament symptoms like popping sounds, bubbles, stringing, and weak layers during 3D printing to avoid poor print quality and wasted material.
SH03 Filament DryerHow to Fix Filament Popping During 3D Printing
Stop filament popping during 3D printing by drying filament, adjusting temperature, and cleaning the nozzle for smoother, stronger prints.
SH03 Filament DryerWhat Makes Sovol SH03 Dryer Stand Out for 3D Printing Filament Care
Sovol SH03 Dryer offers dual chambers, fast heating, and auto dehumidification for efficient, quiet 3D printing filament care and consistent print quality.
