Method
Contactless
Precision
Durability
Ideal For
Eddy Current
✅ Yes
🚀 Fast
🎯 High
💪 Very High
Large-format/industrial
BLTouch
❌ No
⚙️ Medium
👍 Good
⚠️ Moderate
Desktop printers
Capacitive
✅ Yes
⚙️ Medium
👌 Moderate
⚠️ Sensitive
Smooth non-metal beds
Manual
❌ No
🐢 Slow
🤷♂️ Variable
🧰 N/A
Entry-level users
Whether you're printing:
  • Full-size cosplay props
  • Industrial jigs or fixtures
  • Architectural models
  • Multi-part batch runs
💬 Want to Learn More?
How to Fix Z Wobble in 3D Printing Step by Step
Fix Z wobble 3D printing issues with step-by-step solutions for smoother prints. Identify causes, align parts, and maintain your printer for best results.
How to Calibrate 3D Printer Acceleration and Jerk Settings
Calibrate 3D printer acceleration and jerk for smoother prints, fewer defects, and longer machine life. Find safe settings and step-by-step adjustment tips.
SH03 Filament DryerFilament Dryer Worth It Pros and Cons for 3D Printing in 2025
Is a filament dryer worth it for 3D printing in 2025? See pros, cons, and if a filament dryer improves print quality, reliability, and saves money.
