Method
Contactless
Precision
Durability
Ideal For
Eddy Current
✅ Yes
🚀 Fast
🎯 High
💪 Very High
Large-format/industrial
BLTouch
❌ No
⚙️ Medium
👍 Good
⚠️ Moderate
Desktop printers
Capacitive
✅ Yes
⚙️ Medium
👌 Moderate
⚠️ Sensitive
Smooth non-metal beds
Manual
❌ No
🐢 Slow
🤷♂️ Variable
🧰 N/A
Entry-level users
Whether you're printing:
  • Full-size cosplay props
  • Industrial jigs or fixtures
  • Architectural models
  • Multi-part batch runs
💬 Want to Learn More?
