2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
How to Fix Layer Shifting in 3D Printing with Simple Steps
Fix layer shifting 3D printing issues by tightening belts, adjusting speed, and maintaining your printer for accurate, high-quality 3D prints.
How to Stop Stringing in 3D Printing with Simple Retraction Tweaks
Stop stringing in 3D printing by adjusting retraction distance and speed. Achieve cleaner prints with simple slicer tweaks and proper filament care.
Understanding the Differences Between Over Extrusion and Under Extrusion in 3D Printing
Over extrusion vs under extrusion 3D printing: Compare causes, symptoms, and effects to improve print quality and avoid common filament issues.
