2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
Beginner-Friendly Ways to Smooth 3D Prints and Reduce Layer Lines
How to get smoother 3D prints: Adjust print settings, sand, prime, and use simple post-processing steps to reduce layer lines for a polished finish.
Simple Tips to Fix 3D Printing Blobs and Zits
Fix 3D print blobs and zits by adjusting retraction, temperature, and filament care for smoother, high-quality prints.
How to Fix Layer Shifting in 3D Printing with Simple Steps
Fix layer shifting 3D printing issues by tightening belts, adjusting speed, and maintaining your printer for accurate, high-quality 3D prints.
