SLA, DLP, LCD, and FDM Explained: What Makes Each 3D Printing Technology Unique
When you compare SLA, DLP, LCD, and FDM 3D printing technologies, you’ll notice significant differences. Each type of printer—SLA, DLP, LCD, and FDM—operates in its own unique way and uses specific materials. For instance, FDM printers work by melting and extruding hard thermoplastic filaments, while SLA and DLP printers use light to cure liquid photopolymer resin. LCD printers also use UV light and an LCD screen to harden resin. The table below highlights what sets SLA, DLP, LCD, and FDM technologies apart:
Technology
Process
Resolution
Cost
Post-Processing
FDM
Pushes out melted filament
Thermoplastic filament
0.25 mm nozzle
Very little needed
SLA
UV laser hardens resin
Photopolymer resin
25 microns
Needs cleaning and more hardening
DLP
Shines light to harden resin
Photopolymer resin
5 microns
LCD
Uses UV lights and LCD screen
Photopolymer resin
Not as sharp
Medium
The choice between SLA, DLP, LCD, and FDM 3D printing technologies will affect your print quality, speed, and overall cost.
  • FDM printers melt plastic strings to make strong parts fast. They are good for people new to 3D printing. They also work well for big or simple models.
  • SLA and DLP printers use light to harden resin. They make prints with lots of detail and smooth surfaces. These are great for jewelry, dental models, and exact prototypes.
  • LCD printers give a good mix of detail, speed, and low price. They are good for miniatures, dental models, and small engineering parts.
  • Resin printers (SLA, DLP, LCD) need extra cleaning and curing after printing. They use special resins. FDM printers need less work after printing and use regular plastic strings.
  • Pick your 3D printer based on what you need. Choose FDM for fast prints and saving money. Pick SLA or DLP for the best detail. LCD is good if you want quality and speed for less money.
Quick Comparison of SLA, DLP, LCD, and FDMQuick Comparison of SLA, DLP, LCD, and FDM
Overview Table
Here is a side-by-side look at the main features of each 3d printing technology. This table helps you see how sla、dlp、lcd、fdm printers compare in process, speed, materials, print quality, and cost.
Technology
Process
Materials
Cost
FDM
Melts and deposits plastic filament
1-2 days (faster for small parts)
PLA, ABS, PETG, more
Good for prototypes, visible layers
SLA
Uses UV laser to cure resin
3-5 days
Photopolymer resin
Very high, smooth surface
DLP
Uses digital light projector to cure resin
3-5 days
Photopolymer resin
Highest detail, thin layers
LCD
Uses lcd light curing with UV light and LCD screen
3-5 days
Photopolymer resin
High, but not as sharp as DLP
Medium
Note: FDM printers often finish jobs faster than resin printers. Resin-based 3d printing, including sla、dlp、lcd、fdm, gives you higher detail but takes more time and post-processing.
Key Differences
You will notice some clear differences when you compare these 3d printing technology types:
  • Light Source:
    • SLA uses a UV laser.
    • DLP uses a digital projector.
    • LCD uses lcd light curing with an LCD screen and UV light.
    • FDM does not use light; it melts plastic filament.
  • Print Speed:
    • FDM printers usually finish faster, especially for simple or large parts.
    • SLA, DLP, and LCD light curing printers take longer because they cure resin layer by layer.
  • Material Compatibility:
    • FDM works with many thermoplastic filaments like PLA and ABS.
    • SLA, DLP, and LCD light curing printers use only photopolymer resins.
  • Print Quality:
    • DLP and SLA offer the highest detail and smoothest surfaces.
    • LCD light curing gives you good detail but not as sharp as DLP.
    • FDM prints show more visible layers but can be strong and accurate for some uses.
  • Cost:
    • FDM printers and materials cost less.
    • SLA, DLP, and LCD light curing printers and resins cost more.
You can see that sla、dlp、lcd、fdm each have unique strengths. If you want fast, low-cost prints, FDM is a good choice. If you need high detail, choose a resin printer like SLA, DLP, or LCD light curing.
SLA 3D Printing
How It Works
SLA light curing 3d printers use a UV laser to make each layer. The laser moves over liquid resin and hardens it where it shines. When one layer is done, the platform moves down. Then, the printer starts the next layer. This keeps going until the model is finished. SLA light curing makes very thin layers and smooth surfaces. Every stereolithography 3d printer uses this technology.
Features
SLA light curing 3d printers are known for high resolution and accuracy. They can make layers as thin as 25 microns. This means you can print models with sharp details. The quality of models from SLA light curing 3d printers is very good. You can use many kinds of photosensitive resin. Some are clear, tough, flexible, or safe for the body.
Tip: The way you place your print and supports can change how strong and smooth your 3d prints are.
Pros and Cons
Pros:
  • High resolution and smooth finish
  • Works with many photosensitive resin types
  • Good for detailed 3d printed models
Cons:
  • Needs cleaning and extra curing after printing
  • Resin is messy and must be handled with care
  • SLA light curing 3d printers cost more than FDM printers
Materials
You can use many materials with SLA light curing 3d printers. The table below lists some common resin types and what they are used for:
Resin Type
Performance Characteristics
Typical Applications
Standard Resins
Smooth surface, high detail, not very strong
Fast prototypes, display models
Engineering Resins
Strong, tough, like plastic
Working parts, machine pieces
Flexible Resins
Soft and bendy
Soft parts, art projects
Clear Resins
See-through, resists water
Light parts, lens samples
Durable/Tough Resins
Tough, does not break easily
Real parts, strong prototypes
Specialty Resins
Very stiff, heat safe, stops static
Special jobs, static-safe tools
Applications
SLA light curing 3d printers are used for many things:
  • Dental models and surgery guides (because of safe photosensitive resin)
  • Jewelry and small models that need fine detail
  • Engineering and high-precision prototypes
  • Clear parts and light guides
  • Strong parts made with tough or special resins
SLA light curing 3d printers give great quality, thin layers, and many material choices. You get good results for both easy and hard 3d printing jobs.
DLP 3D Printing
How It Works
DLP light curing 3d printers use a digital projector. The projector shines patterns of light onto liquid resin. Each layer forms when the light cures the resin all at once. This is different from curing one spot at a time. DLP light curing is fast and very accurate. After each layer, the build platform moves up or down. You can watch your 3d model grow as it prints. DLP 3d printing can make very tiny features, even as small as 1 micron. This is much finer than most other 3d printing methods.
Features
DLP light curing 3d printers are fast and make detailed prints. You can print shapes with sharp edges and smooth surfaces. The technology uses two types of light, 405 nm and 365 nm. This helps control how the resin hardens. You can change the mechanical properties of your 3d prints. Grayscale imaging lets you use different shades in your prints. You can also switch vats to use different materials in one job.
Tip: DLP light curing 3d printers can cure a whole layer in just 1 to 4 seconds with dual-wavelength light. This makes them much faster than older printers.
Here is a table with important numbers for DLP light curing 3d printing:
Parameter
Value/Range
What It Means
Resolution
Down to 1 µm
Prints very fine details
Printing speed
0.5 to 15 mm/s
Fast production
Layer cure time (dual)
1–4 s per 100 µm layer
Quick layer curing
Feature size (microneedle)
~20 µm
High accuracy for small parts
Light wavelengths
405 nm and 365 nm
Dual-wavelength for better control
Pros and Cons
Pros:
  • You get high resolution and smooth surfaces.
  • DLP light curing 3d printers work quickly, even for small parts.
  • You can print with many types of photosensitive resin.
  • The printer can make complex shapes and tiny features.
Cons:
  • DLP light curing 3d printers and resins cost more than FDM.
  • You must clean and cure your prints after printing.
  • Some resins are not as strong as SLA resins.
  • The build area is usually smaller than FDM printers.
Materials
You can use many materials with DLP light curing 3d printers. Most DLP printers use photosensitive resin that hardens with light. These resins come in different types for different needs. Some are strong, some are flexible, and some are clear. DLP resin 3d printing lets you pick the best material for your project.
Resin Type
Properties
Common Uses
Standard Resin
Good detail, smooth finish
Prototypes, models
Tough Resin
Higher impact resistance
Functional parts, tools
Flexible Resin
Bends without breaking
Wearables, soft parts
Clear Resin
Transparent, smooth
Lenses, light guides
Specialty Resin
Heat-resistant, static-safe, etc.
Engineering, electronics
You can make your prints stronger and more accurate by changing the layer thickness. If you make the layer thinner, your print can be up to 59% more accurate. The best layer thickness for strong parts is often about 0.15 mm.
Applications
You can use DLP light curing 3d printers for many jobs. These printers are great for dental models, jewelry, and medical devices. They print fine details very well. You can also make engineering prototypes, microneedles, and small mechanical parts. DLP resin 3d printing is good for any project that needs high accuracy and smooth surfaces.
Note: DLP light curing 3d printers can make complex biological shapes. For example, they can print blood vessels from 5 microns to 3 centimeters. This makes them helpful in medical research.
LCD 3D Printing
How It Works
You use lcd 3d printing when you want to create detailed models with a light curing 3d printer. This process uses an LCD screen and UV light to cure photosensitive resin. The LCD screen acts like a mask. It lets light pass through only where you want each layer to harden. The printer cures an entire layer at once. You get fast results and sharp details. Each time a layer finishes, the build platform moves, and the next layer starts. This method gives you smooth surfaces and accurate shapes.
Features
LCD 3d printing gives you a mix of speed, detail, and cost savings. You can print many models at once on the same platform. The printer uses lcd light curing to make thin layers, often as fine as 47 microns. Some models, like the Ackuretta Sol, reach print speeds up to 45 mm per hour. You can see how different printers compare in the table below:
Printer Model
Technology
Build Platform Size (mm)
Max Print Speed (mm/h)
XY Resolution (μm)
Anycubic Photon
LCD-based SLA (405nm)
115 × 65 × 155
20
47
Anycubic Photon S
115 × 65 × 165
20
47
Elegoo Mars
119 × 68 × 155
22.5
47
Ackuretta Sol
LCD-based SLA (385/405nm)
128 × 80 × 120
45
49
Grouped bar chart comparing max print speed and XY resolution for LCD 3D printers
You get reliable accuracy with lcd light curing. Budget printers like Anycubic Photon and Elegoo Mars offer accuracy close to more expensive models. You can trust lcd 3d printing for both hobby and professional work.
Pros and Cons
Pros:
  • You get high detail and smooth surfaces.
  • LCD light curing 3d printer models cost less than many other types.
  • You can print several models at once, saving time and resin.
  • The process uses less photosensitive resin when you print hollow models.
Cons:
  • Some lcd light curing 3d printer models have smaller build areas.
  • Prints may not be as sharp as DLP, but still look very good.
Tip: You can save resin and money by printing models vertically or hollow. The right orientation makes lcd 3d printing more efficient.
Materials
You use photosensitive resin as the main material in lcd 3d printing. These resins come in many types. You can choose standard, tough, flexible, or clear options. Each type gives you different results. The table below shows how your choices affect resin use and cost:
Model Type / Orientation
Resin Consumption per Model
Cost per Model (USD)
Number of Models per Print Platform
Hollow (Shell), Vertical
9 mL
$1.35
15
Uses less resin, more economical
Solid, Vertical
17 mL
$2.50
15
Consumes nearly twice the resin
Horizontal (50 models)
915 gm total
$558.15 total
Significant material and cost savings
Vertical (50 models)
1989 gm total
$1,213.29 total
Nearly double resin and cost vs horizontal
You can see that lcd light curing 3d printer models let you control how much photosensitive resin you use. This helps you manage costs and waste.
Applications
You can use lcd 3d printing for many jobs. This technology works well for dental models, jewelry, and small engineering parts. You get fine details and smooth finishes. Many people use lcd light curing for prototypes, miniatures, and custom tools. You can also print art pieces and educational models. The process fits both home and business needs.
Note: LCD light curing 3d printer models give you a balance of speed, detail, and cost. You can choose the right photosensitive resin for your project and get great results every time.
FDM 3D PrintingFDM 3D Printing
How It Works
You use fdm 3d printing to make things by stacking melted plastic. The printer heats up a thermoplastic filament until it gets soft. Then, the machine pushes the filament through a nozzle. It draws each layer on a flat surface. When one layer cools, the next layer goes on top. This keeps happening until your 3d model is finished. You can watch your design grow as each layer is added.
Features
Fdm 3d printing is simple and flexible. You can pick from many plastic filaments like PLA or ABS. The printer lets you change settings such as layer height and speed. You can print big or small models. You can also pause or restart the print if you need to. Both beginners and experts like fdm 3d printing because it is easy to use.
Tip: You can change the layer thickness. Thicker layers print faster. Thinner layers make smoother surfaces.
Pros and Cons
Pros:
  • You get strong parts that work for real jobs.
  • FDM 3d printing uses cheap materials, so you save money.
  • The process is fast for simple shapes and needs little extra work.
  • You can use open-source software to adjust your prints.
Cons:
  • You might see lines between each layer.
  • The accuracy is lower than resin-based 3d printing.
  • Setup can be tricky with many settings to change.
  • Room temperature and other factors can affect print quality.
Here is a quick comparison between fdm 3d printing and SLA 3d printing:
FDM 3D Printer
SLA 3D Printer
Material Cost
Uses cheap, easy-to-find thermoplastics (PLA, ABS); lower cost per part
Uses special, more costly resins with shorter shelf life
Print Speed & Throughput
Prints basic parts faster; needs little extra work
Prints slower; needs extra washing and curing
Labor & Handling
Needs less hands-on time; parts are ready fast or need small cleanup
Needs more work after printing and safety steps
Part Strength
Makes strong parts good for real use
Parts have more detail but are not as tough
Workflow Simplicity
Easier setup and printing
More steps and longer post-processing
Materials
You can use many filaments with fdm 3d printing. PLA and ABS are the most common. You can also use PETG, nylon, or flexible TPU. Each material has its own good points. PLA is easy to print and great for beginners. ABS is stronger and can handle heat. PETG is both strong and flexible. Some printers let you use special filaments with wood or metal bits.
Applications
Fdm 3d printing helps you make prototypes, tools, and spare parts. Many industries, like aerospace and car makers, use this for big, complex pieces. You can make custom phone cases, toys, or even medical devices. Industrial fdm 3d printing gives strong, repeatable results for real parts. This method is good for saving money and getting parts fast.
Note: Home fdm 3d printing can make models almost as accurate as pro machines. You get good results for many projects, from school to business.
Comparing 3D Printing Technology
Print quality means how smooth and detailed your models look. SLA and DLP printers make the best-looking prints. They use light to harden resin, so you get smooth and sharp details. DLP printers can make very tiny features, even down to 1 micron. SLA printers also give high resolution and smooth finishes. LCD printers are close, especially when they control light for each pixel, but they are not as sharp as DLP or SLA.
FDM printers make strong parts, but you will see lines between layers. They are not as accurate as resin printers. If you want the best detail for small objects, pick SLA or DLP. If you want good quality for bigger, stronger parts, FDM is a good choice.
Tip: You can make FDM prints smoother by sanding or using special sprays.
A big study shows SLA, DLP, and PolyJet have the best accuracy. You can check this with RMS and mean deviation numbers. These numbers help you see which printer is most accurate.
Speed is important if you need your models fast. FDM printers usually finish quicker, especially for simple or big parts. They melt and lay down plastic one layer at a time. This works well for test models and working parts.
DLP and LCD printers cure a whole layer at once, so they are faster than SLA for some jobs. SLA uses a laser to draw each layer, so it can be slower, especially for tricky shapes. But DLP and LCD still need extra time for cleaning and curing, which adds to the total time.
Here is a table that shows speed and build size for each type:
Technology Category
Max Build Volume (mm)
Advantages
Disadvantages
Vat Photopolymerization (SLA/DLP/LCD)
~2100 x 700 x 800
High resolution; fast for small parts
Limited part size; post-processing needed
Material Extrusion (FDM)
~1005 x 1005 x 1005
Inexpensive; scalable; fast for big parts
Poor surface quality; limited accuracy
Note: DLP and LCD printers can cure a layer in seconds. FDM speed depends on layer height and part size.
Cost
Cost is a big thing to think about when picking a printer. FDM printers are the cheapest. You can get a starter model for about $200. The filament is cheap and easy to buy. SLA and DLP printers cost more, starting at $2,000 and going much higher for big machines. Resin also costs more than filament.
LCD printers cost less than SLA and DLP, but you will need to replace the screen and other parts sometimes. Cleaning and curing also cost more, especially for resin printers.
Here is a table that compares costs:
Technology
Initial Printer Price Range
Material Type
Post-Processing Cost
Notes on Operational Costs
FDM
$200+ (hobbyist) to $200,000+ (industrial)
Filaments
$3,000+
Most affordable; simple post-processing
SLA
$2,000 to $200,000+
Liquid resin
$1,000+
High resolution; solvent cleaning needed
DLP
Comparable to SLA, higher for large models
Liquid resin
$30,000+
Fast, high throughput; limited materials
LCD
Lower than SLA and DLP
Liquid resin
$1,000+
Fast curing; frequent consumable replacement
Bar chart showing post-processing costs for 3D printing technologies
Tip: FDM saves money on printers and materials, but resin printers give more detail for a higher price.
Ease of Use
You want a printer that matches your skills. FDM printers are easy to use and set up. Many beginners start with FDM because it is simple and the software is easy. You just load the filament, level the bed, and start printing.
Resin printers like SLA, DLP, and LCD need more steps. You must handle liquid resin, clean the prints, and cure them with UV light. This can be messy and takes practice. Most people find FDM easier to use. About 73% of users need help with 3d printing, and only 21.6% feel sure they can print alone.
Data
Percentage of users with any 3d printing experience
31.1%
Mean self-reported difficulty rating (scale 1-5)
3.14
Mean self-reported skill level (scale 1-5)
2.54
Percentage needing help with 3d printing tasks
73.0%
Common reported barriers
Creating digital 3D models, lack of material knowledge, printer/software settings
Percentage feeling capable of creating 3d printed objects independently
21.6%
Note: Pick a printer with a simple interface and good support to make things easier.
Post-Processing
Post-processing is what you do after printing. FDM prints need you to remove supports and maybe sand the surface. This is easy and does not need chemicals.
SLA, DLP, and LCD printers need more work. You must wash the prints in a solvent to get rid of extra resin. Then, you cure them under UV light to make them strong. This takes more time and care. SLA prints come out the smoothest, so you spend less time finishing the surface. DLP and LCD prints need the same extra steps.
Laser SLA (L-SLA)
DLP SLA
MSLA / LCD SLA
Curing Method
UV laser draws layer point-by-point
Digital projector flashes entire layer image
UV LED array + LCD screen flashes entire layer
Slower, especially for large/solid layers
Faster than laser, cures whole layer simultaneously
Fastest, cures whole layer simultaneously
Post-Processing
Resin washing and UV curing
Same as Laser SLA
Same as Laser SLA
Pros
Mature tech, large build volumes
Fast layer times, good accuracy
Very fast, cost-effective, high resolution
Cons
Slower for complex layers, more expensive
Projector resolution limits detail, expensive bulbs
LCD screen lifespan limited, visible pixel grid
Tip: Always wear gloves and work in a place with fresh air when using resin.
Best Uses
Each printer type is best for different jobs. Here is a quick guide to help you choose:
  • FDM: Good for test models, big parts, and working objects. You save money and get strong prints.
  • SLA: Great for detailed models, dental work, jewelry, and engineering samples. You get smooth surfaces and fine details.
  • DLP: Best for small, detailed parts that need high accuracy and fast printing. Used in medical, dental, and tiny machine parts.
  • LCD: Good for cheap, high-detail prints. Works well for miniatures, dental models, and small engineering parts.
If you want the best detail and smoothest finish, pick SLA or DLP. If you want fast, strong, and cheap parts, FDM is best. LCD printers give you a mix of speed, detail, and cost.
Remember: Pick the 3d printing technology that fits your project needs for the best results.
You have many options when choosing a 3D printer. SLA and DLP give you smooth, detailed prints. LCD offers good detail at a lower cost. FDM makes strong, affordable parts fast. Your best choice depends on what you need most—detail, speed, or budget.
Comparison
SMD
95% CI
Significance
DLP vs SLA
≈ 0
CI crosses zero
Not significant
DLP vs FDM
≈ 0
CI crosses zero
Not significant
LCD vs SLA
≈ 0
CI crosses zero
Not significant
Bar chart showing SMD values for SLS vs DLP, LCD, FDM, and SLA
Tip: Match your project to the printer’s strengths. For fine detail, pick SLA or DLP. For quick, strong parts, choose FDM. LCD works well for budget-friendly, detailed models.
What is the easiest 3D printing technology for beginners?
You will find FDM printers the easiest to use. You load the filament, start the print, and remove the finished part. You do not need to handle messy resins or do extra cleaning.
Can I use the same materials in all 3D printers?
No, you cannot. FDM printers use plastic filaments like PLA or ABS. SLA, DLP, and LCD printers use liquid resin. You must choose the right material for your printer type.
How do I make my 3D prints smoother?
You can sand FDM prints or use a smoothing spray. For resin prints, adjust the layer height and clean the model well. Thinner layers give a smoother finish.
Which 3D printing method gives the strongest parts?
FDM printing gives you the strongest parts for most uses. You can pick tough filaments for extra strength. Resin prints look smoother but break more easily.
Do I need special safety steps for resin printers?
  • Yes, you do.
  • Wear gloves and goggles.
  • Work in a room with good airflow.
  • Wash your hands after handling resin.
  • Always follow the safety tips in your printer’s manual.
