15 Easy Christmas 3D Print Ideas for Beginners
Looking for easy Christmas 3D prints to make your holiday fun? You can create cool decorations and gifts with a 3D printer. These beginner prints feature easy designs and do not take long to print. They are also simple to put together. Here are some things that make these easy Christmas 3D prints great for your holiday projects:
Characteristic
Examples
Ease of printing
Easy and fast prints for beginners
Gingerbread Cookie Cutter
Fun themes
Every design has a holiday feel
Snowman, Nutcracker
Practicality
Good for gifts or decorations
Present Ornament, Tea Light
Creativity
You can add your own colors or build them
Nutcracker, LEGO Men
Show your creativity this Christmas and enjoy these fun and easy Christmas 3D prints!
  • 3D printing Christmas ornaments lets you be creative. You can pick colors and shapes. You can also add names to your decorations. This makes each one special.
  • Easy designs like ball ornaments and snowflakes are fast to print. They do not need much assembly. These projects help you get better at 3D printing.
  • Making your own holiday gifts is fun. You can make things like reindeer keychains or cookie cutters. These gifts are special because you made them. They show your loved ones you care.
Easy Christmas 3D Prints: Ornament Ideas
Making your own holiday decorations is a fun part of 3D printing. You can make special 3d printed christmas ornaments that show your style. These ornaments help your home feel unique and cozy. Store-bought ornaments do not let you change much. With 3d printed ornaments, you get to decide how they look. You can change the design, pick colors you like, and add names or messages. This makes your holiday decorations feel more special and easy to remember.
Here are some easy christmas 3d prints that many beginners enjoy. Each idea has tips to help you start. You can fill your tree and home with bright, happy decorations.
1. Classic Ball Ornament
A classic ball ornament is perfect for any Christmas tree. You can print them in any color you want. They look nice on the tree, in a bowl, or on gifts.
  • Why it's beginner-friendly:
    The shape is simple and round. You do not need to worry about hard angles or supports. Most slicers work well with spheres. You can print them in one piece or two halves.
  • Recommended filament: PLA (red, green, gold, or silver look festive)
  • Estimated print time: 1-2 hours for each ornament
  • Difficulty: Easy
  • Typical use case: Tree decorations, table centerpieces, or gift toppers
  • Printing tips:
    • Layer height: 0.2mm for smoothness
    • Infill: 10-15% keeps ornaments light
    • Supports: Not needed if you print halves; only a little needed for whole spheres
    • Add a loop at the top to hang it
Tip: Paint or add glitter to your 3d printed ornaments for extra shine!
2. Snowflake Ornament
Snowflakes are a winter favorite and look pretty as 3d printed christmas ornaments. Hang them on your tree, put them in windows, or make a garland.
    Snowflake ornaments use easy shapes like squares and rectangles. You can make your own in TinkerCAD or use a file from the internet. Most snowflakes print flat in two pieces. You can glue or slot them together. This makes them easy to build and you do not need tricky supports.
  • Recommended filament: PLA (white or blue for a frosty look)
  • Estimated print time: 30-45 minutes for each snowflake
  • Difficulty: Easy
  • Typical use case: Tree decorations, window hangings, or garlands
  • Printing tips:
    • Layer height: 0.2mm for good detail
    • Infill: 10% is enough
    • Supports: Not needed for flat snowflakes
    • Print a few at once to save time
Note: Snowflakes are great for practicing 3d printing because they are quick and easy.
3. Mini Christmas Tree
A mini 3d printed christmas tree is a cute holiday decoration. Use them as ornaments, on tables, or in a winter village.
    The design uses stacked cones or simple shapes. Many files let you change the height or add stars and baubles. Most mini trees do not need supports.
  • Recommended filament: PLA (green for trees, yellow for stars, or use many colors)
  • Estimated print time: 1-2 hours for each tree
  • Difficulty: Easy
  • Typical use case: Tree decorations, table centerpieces, or holiday displays
  • Printing tips:
    • Layer height: 0.2mm for speed and detail
    • Infill: 15% for strength
    • Supports: Not needed for most trees
    • Print a base so the tree stands up
You can make your mini trees special by gluing beads or painting ornaments.
4. Candy Cane
Candy canes are a sweet sign of the holidays. 3d printed ornaments shaped like candy canes look nice on trees, wreaths, or tables.
    Candy cane designs are simple and print flat or as one curved piece. You can use two-color filament or paint stripes after printing.
  • Recommended filament: PLA (red and white for a classic look)
  • Estimated print time: 30-60 minutes for each candy cane
  • Difficulty: Easy
  • Typical use case: Tree decorations, stocking stuffers, or table accents
  • Printing tips:
    • Infill: 10%
    • Supports: Not needed for flat candy canes
    • Use a raft if your printer has trouble with small parts
Make a bunch of candy canes and tie them with ribbon for a festive look.
5. Bell Ornament
Bells are a classic part of christmas decorations. 3d printed bell ornaments add a special touch to your tree or mantel. Print them in shiny colors or in red and gold.
Ornament Type
Durability
Customization Options
Traditional Ornaments
Often break easily but last if stored well
Not many ways to change them
3D Printed Ornaments
Plastics may fade or chip over time
You can change the design and color a lot
    Bell designs are hollow and print in two parts. You can put them together easily. Add a clapper inside for a real jingle. 3d printed ornaments let you pick the size and color to match your theme.
  • Recommended filament: PLA (gold, silver, or any color you like)
  • Estimated print time: 1-1.5 hours for each bell
  • Difficulty: Easy
  • Typical use case: Tree decorations, mantel displays, or wreaths
  • Printing tips:
    • Infill: 10-15%
    • Supports: May be needed for the bell’s overhang
    • Print the clapper by itself and tie it with string
3d printed christmas ornaments like bells are stronger than glass and you can make them your way.
6. Santa Miniature
Santa miniatures are always fun for christmas 3d prints. Use them as tree ornaments, table pieces, or collectibles. Kids love finding Santa in holiday displays.
Use Case
Home decoration
Makes homes feel more festive
Christmas ornament
Looks nice on trees or mantels
Collectible display
Great for people who collect holiday figures
Heartwarming gift
A thoughtful present for friends and family
    Many Santa designs are made for beginners. They use simple shapes and not much detail. You can print them in one piece or in parts for painting.
  • Recommended filament: PLA (red, white, and black for Santa)
  • Estimated print time: 1-2 hours for each Santa
  • Difficulty: Easy to Medium (depends on detail)
  • Typical use case: Tree decorations, gifts, or collectibles
  • Printing tips:
    • Layer height: 0.2mm for basic, 0.1mm for more detail
    • Infill: 15%
    • Supports: May be needed for Santa’s hat or arms
    • Paint details after printing to make it special
Santa miniatures are great 3d printed christmas decorations and make nice gifts.
Why Choose 3D Printed Christmas Ornaments?
When you make your own 3d printed christmas ornaments, you get more than just decorations. You can change every part, like color, shape, and message. Here’s how 3d printed ornaments compare to store-bought ones:
Store-Bought Ornaments
Personalization
High - you can make each one unique
Low - only a few choices
Creative Control
Lots - you can use your imagination
Not much - only what is sold
Iterative Design
Yes - you can change and reprint
No - you get what you buy
Meaningfulness
High - can show your own stories
Low - usually not personal
You can print as many as you want and try new 3d printing ideas. Your family can help pick colors or add finishing touches. This makes your holiday decorations special and one-of-a-kind.
Popular 3D Printed Christmas Ornaments for Beginners
Many beginners like making these 3d printed christmas ornaments:
  • Santa and Snowman containers (easy, no supports needed)
  • Customizable christmas tree ornaments
  • Spinning tree decorations for tables
  • Articulated christmas toys
  • Simple "Merry Christmas" tree ornaments
You can find lots of free designs online. You will always have new ideas for your next project.
Making your own 3d printed ornaments is a fun way to learn and make memories. Try these easy christmas 3d prints and see your holiday decorations come alive!
Christmas 3D Prints: Decor Ideas
You can make your home feel magical with christmas 3d prints that go beyond ornaments. These easy christmas 3d prints help you decorate every corner. You get to show off your creativity and add a personal touch to your space. Many people love using 3d printed decorations because they are simple to make and look amazing. Let’s check out some fun and easy ideas you can try this holiday season.
1. Festive Lantern
A festive lantern brings a warm glow to your holiday nights. You can place it on your table, windowsill, or even by the fireplace. Many lantern designs feature stars, snowflakes, or even favorite characters like Baby Yoda or Harry Potter. These lanterns make your home feel cozy and bright.
  • Why it’s beginner-friendly:
    Most lanterns use basic shapes like cubes or cylinders. You can print them in separate panels and snap them together. There’s no need for tricky assembly.
  • Recommended filament: PLA (white, gold, or red look great)
  • Estimated print time: 3-5 hours, depending on size and detail
  • Difficulty: Easy
  • Printing tips:
    • Layer height: 0.2mm for a good mix of speed and detail
    • Supports: Needed for window cutouts or overhangs
    • Print in sections if your printer has a small bed
Tip: Place a battery-operated LED candle inside your lantern for a safe, flickering effect. Real candles can get too hot for 3d printed decorations.
2. Wreath Ring
A wreath ring is a classic piece of christmas decor. You can hang it on your door, above your mantel, or use it as a table centerpiece. 3d printed christmas decorations like wreath rings let you pick the style—simple, leafy, or even with fun shapes like snowmen or bells.
    Wreath rings use simple loops or connected shapes. You can print them flat or in two halves. Most designs do not need supports, which makes them perfect for beginners.
  • Recommended filament: PLA (green for a classic look, or mix in red and white)
  • Estimated print time: 2-4 hours, depending on size
  • Difficulty: Easy
  • Printing tips:
    • Infill: 10-15%
    • Supports: Not needed for most flat designs
    • Add hooks or holes for hanging
You can glue on ribbons, berries, or even small 3d printed ornaments to make your wreath unique.
3. Tea Light Holder
A tea light holder adds a gentle glow to your holiday table or windowsill. You can find designs shaped like stars, trees, or even snowflakes. These holders make your home feel warm and inviting during the winter nights.
    Tea light holders use simple shapes and print in one or two pieces. You can finish them quickly and decorate them with paint or glitter.
  • Recommended filament: PLA (white, silver, or gold)
  • Estimated print time: 1-2 hours per holder
  • Difficulty: Easy
  • Printing tips:
    • Infill: 15%
    • Supports: Needed for some overhangs
Safety Note: Never use real candles in 3d printed tea light holders. Real flames get very hot and can melt or burn the plastic. Always use battery-operated LED candles. This keeps your home safe, especially if you have kids or pets.
4. Holiday Coaster
Holiday coasters protect your table and add a festive touch to your gatherings. You can print coasters with snowflakes, reindeer, or even your family’s name. These coasters make your table look cheerful and keep it clean.
    Coasters are flat and print quickly. You can try two-tone designs or add text for a personal touch. They are a great way to practice 3d printing ideas and make useful gifts.
  • Recommended filament: PLA (red, green, white, or any color you like)
  • Estimated print time: 30-45 minutes per coaster
  • Difficulty: Easy
  • Printing tips:
    • Infill: 10%
    • Supports: Not needed for most designs
    • Try printing a set with different patterns
Holiday coasters bring unique style to your home. You can customize them with greetings or names. They help create a cozy and memorable holiday atmosphere.
Popular 3D Printed Christmas Decor Items
Many people love making these christmas 3d prints for their homes:
  • Baby Yoda holding a gift or drink
  • Gizmo from Gremlins for a cute touch
  • Hogwarts Express train for a magical display
  • Albus Dumbledore and Harry Potter figures for fans
You can add these characters to your holiday displays for extra fun. They are some of the most downloaded 3d printed decorations during the season.
You can see how easy it is to fill your home with 3d printed christmas decorations. These ideas help you create a warm, festive space without much effort. You get to choose the colors, shapes, and even add your own message. With just a few prints, you can turn any room into a holiday wonderland.
Try these christmas 3d prints and watch your home come alive with holiday cheer!
Christmas Gift & Card Ideas
Giving gifts at Christmas feels special when you make them yourself. With your 3D printer, you can create unique presents and cards that show you care. These christmas 3d prints are fun, easy, and perfect for beginners. You can personalize each one, try new 3d printing ideas, and surprise your friends and family with something they have never seen before.
Here are some of the best 3d print gift ideas for the holiday season. Each one is simple to make, uses basic materials, and brings a smile to anyone who receives it.
1. Reindeer Keychain
A reindeer keychain is a cute and practical gift. You can use it as a stocking stuffer, attach it to a backpack, or add it to your keys. Kids love these little reindeer, and adults enjoy them too.
  • Why it’s great for beginners:
    The design is simple and prints flat. You do not need supports or tricky assembly. You can even add a name or year to make it personal.
  • Recommended filament: PLA (brown, red, or any color you like)
Item
Average Print Time
Keychain
30-60 minutes
  • Difficulty: Easy
  • Printing tips:
    • Infill: 15%
    • Add a small hole for the keyringYou can print several reindeer keychains at once. They make great 3d printed gifts for classmates, coworkers, or anyone who loves Christmas.
2. Cookie Cutter
Cookie cutters are a must for holiday baking. You can make cookies shaped like trees, stars, or even a snowman. These cutters turn your kitchen into a Christmas workshop.
    Cookie cutters use simple outlines and print quickly. You can design your own in TinkerCAD or CookieCAD. This is a fun way to try diy 3d print gift ideas.
  • Recommended filament: PLA or PETG (choose food-safe filament)
  • Estimated print time: 30-60 minutes per cutter
  • Difficulty: Easy
  • Printing tips:
  1. Use beginner-friendly software like TinkerCAD or CookieCAD.
  2. Choose food-safe filament.
  3. Make sure details are larger than 1.15 mm and walls are at least 1.2 mm thick.
  4. Mirror any text so it prints correctly.
  5. Layer height: 0.2mm
  6. Infill: 20% for strength
  7. Supports: Not needed
Cookie cutters are perfect for diy gifts. Wrap them with a recipe card for a thoughtful present.
3. Snowman Magnet
A snowman magnet brings a bit of winter cheer to any space. You can stick it on the fridge, a locker, or even your desk at work. Add a ribbon or string, and it becomes a cute ornament for your tree.
    The snowman shape is simple and prints flat. You can paint on a face, buttons, or a scarf. Kids love making and decorating these magnets.
  • Recommended filament: PLA (white for the snowman, orange for the nose, black for the hat)
  • Estimated print time: 30-45 minutes per magnet
  • Difficulty: Easy
  • Printing tips:
    • Infill: 10%
    • Glue a small magnet to the back
Snowman magnets make fun 3d printed gifts for teachers, friends, or anyone who loves snowman decorations. They add a whimsical touch to your holiday.
4. Gift Tag
Gift tags help you label presents and add a personal touch. You can print tags with names, messages, or even a snowman design. These tags look great on any Christmas gift.
    Gift tags are flat and print fast. You can customize them with text or shapes. Try embossing a message or using svg modifiers for extra style.
  • Recommended filament: PLA (red, green, gold, or silver)
  • Estimated print time: 20-30 minutes per tag
  • Difficulty: Easy
  • Printing tips:
    • Select the right print sheet for durability. Some materials stick better to certain surfaces.
    • Infill: 10%
    • Add a hole for ribbon or string
3d printed gift tags are stronger than paper and can be reused. They make your presents stand out under the tree.
5. 3D Printed Christmas Card
A 3D printed Christmas card is more than just a greeting. It’s a keepsake that lasts long after the holiday. You can add pop-up features, a snowman, or even a lithophane for a glowing effect.
    Many designs print flat and fold into shape. You can use single-extruder multicolor printing for extra flair. Try adding your own message or design in PrusaSlicer.
  • Recommended filament: PLA (white, red, green, or any festive color)
  • Estimated print time: 1-2 hours per card
  • Printing tips:
    • Layer height: 0.2mm for speed, 0.1mm for detail
    • Infill: 10%
    • Supports: Not needed for most cards
    • Try adding a lithophane window for a glowing effect
3D printed Christmas cards use premium, sustainable materials. They feature unique designs and pop-up elements that turn your card into a decoration. These cards become conversation starters and treasured keepsakes.
6. Advent Calendar
A 3d printed advent calendar makes counting down to Christmas extra fun. You can fill each compartment with candy, notes, or tiny gifts. Kids love opening a new door every day.
    Advent calendars use simple boxes or drawers. You can print each part separately and assemble them. The process teaches you about designing, post-processing, and painting.
  • Recommended filament: PLA (red, green, white, or mix colors for a festive look)
  • Estimated print time: Several hours for all parts (each box 30-60 minutes)
  • Difficulty: Medium (assembly required)
  • Printing tips:
    • Print each part separately for best results
    • Add guides to help with assembly and reinforce the roof
    • Infill: 15%
Building a 3d printed advent calendar is a great diy project. You learn a lot about 3d printing and get a fun decoration for your home or 3d printed christmas village.
Creative Possibilities with 3D Printed Gifts and Cards
You can do so much with 3d printed gifts and cards. Here are some creative options you can try this holiday:
  • Personalize every gift with names, dates, or special messages.
  • Make unique figurines, cute Christmas creatures, or iconic props from your favorite movies.
  • Try single-extruder multicolor printing for colorful designs.
  • Add lithophanes to cards for a glowing surprise.
  • Design your own models in PrusaSlicer or TinkerCAD.
  • Create jewelry, planters, puzzles, or even a mini 3d printed christmas village.
The best part about diy 3d printed gifts is that you can make them your own. Every project helps you learn new skills and brings joy to your holiday season.
Popular 3D Printed Christmas Gifts for Beginners
Many beginners love making these 3d printed gifts:
  • Personalized keychains and magnets
  • Cookie cutters for baking parties
  • Snowman ornaments and decorations
  • Jewelry and puzzles for stocking stuffers
  • Mini planters for a 3d printed christmas village
You can find lots of free designs online or create your own. These easy christmas 3d prints make your holiday extra special.
Try these 3d print gift ideas and see how much fun you can have with your 3D printer this Christmas!
Printing Tips for Easy Christmas 3D Prints
Common Beginner Issues
You might run into a few bumps when you start christmas 3d printing. Don’t worry—these are easy to fix! Here are some common problems and how you can avoid them:
  • Warping: Your print lifts at the corners. Try using a heated bed or add a brim in your slicer settings.
  • Poor bed adhesion: Prints don’t stick. Clean your print bed and use a glue stick or painter’s tape.
  • Stringing: Thin threads appear between parts. Lower your print temperature or adjust retraction settings.
  • Supports confusion: Some easy christmas 3d prints need supports, but many holiday designs print flat. Always check your file before starting.
Tip: Start with simple 3d printing ideas. You’ll learn faster and see great results for your holiday projects.
Best Practices for Holiday Prints
You want your holiday prints to look bright and festive. Try these tips to make your christmas decorations stand out:
  • Pick bold colors like red, green, gold, or silver for a classic holiday look.
  • Paint your prints or add glitter for extra sparkle.
  • For a smooth finish, apply a thin layer of epoxy or UV-curable resin. You can also use acetone vapor for ABS or ethyl acetate vapor for PLA to get a shiny surface.
  • Assemble parts with super glue or snap-fit designs for easy building.
  • Add names or messages to personalize your gifts and decorations.
Remember, every print is a chance to try new ideas and make your holiday special. Have fun and let your creativity shine with christmas 3d printing!
Recommended 3D Printer Settings for Christmas Prints
Getting your 3D printer settings right makes your holiday projects shine. With the right setup, you can turn your favorite christmas 3d printing ideas into beautiful decorations and gifts. Here’s how you can get the best results for your festive prints.
Layer Height & Speed
Layer height affects how smooth and detailed your prints look. For most holiday prints, you want a balance between speed and quality. Check out this table for the best layer heights based on your nozzle size:
Nozzle Diameter
Recommended Layer Height Range
0.2mm
0.05 - 0.15mm
0.4mm
0.1 - 0.3mm
0.6mm
0.15 - 0.45mm
0.8mm
0.2 - 0.6mm
1.0mm
0.25 - 0.75mm
1.2mm
0.3 - 0.9mm
For PLA, stick to 0.1mm to 0.3mm for high-quality christmas prints. Lower heights like 0.1mm give you smooth surfaces, perfect for ornaments and detailed holiday decorations.
Bar chart showing recommended layer height ranges for different nozzle diameters
Print speed matters too. Try 40-60mm/s for most holiday projects. Slower speeds help with small details and reduce print errors.
PLA Filament Tips
PLA is the best choice for your holiday 3d printing ideas. Here’s why you’ll love it:
  • Easy to print and doesn’t smell bad.
  • Works well for beginners—no special equipment needed.
  • Gives you smooth, colorful, high-quality prints.
  • Made from plants, so it’s more eco-friendly.
  • Biodegradable under the right conditions.
  • Affordable and easy to find in stores or online.
You can pick from many colors to match your christmas theme.
Bed Adhesion & Supports
Good bed adhesion keeps your holiday prints from warping or peeling up. Try these tips:
  • Use a heated bed to keep your model warm and flat.
  • Add glue, painter’s tape, or a textured bed for extra grip.
  • For most flat christmas prints, you won’t need supports. If your design has overhangs, turn on supports in your slicer.
Tip: Always check your first layer. A smooth start means fewer problems later!
With these settings, you’ll turn your holiday 3d printing ideas into festive masterpieces.
Where to Find Free Christmas STL Files
If you want free STL files for Christmas, there are lots of places online. You can find cool decorations, gifts, and ornaments to print at home. Let’s look at where you can get festive ideas and how to pick easy designs for beginners.
Online Repositories
Many websites have free Christmas STL files. You can search, download, and print models for the holidays. Here are some popular places to find holiday designs:
  • Cults3D: This site has a big collection of Christmas models. You can find ornaments and glowing gift boxes.
  • Other community sites: These sites have holiday files like tiny villages, shiny trees, and winter castles.
  • Maker forums: Join forums to share ideas and get help with printing decorations.
Tip: Check print settings and read reviews before you start a project. This helps you avoid problems and get good results.
Choosing Beginner-Friendly Designs
Pick Christmas STL files that are easy and fun. Look for these things:
  • Simple shapes that print flat or in one piece.
  • Designs that say “easy to print” or “no supports needed.”
  • Models with cool features, like glowing parts or spots for LEDs.
  • Festive themes, like decorated houses, trains, or shiny trees.
Choose designs that match your style to make your prints special. Try adding your own colors or lights for extra fun. You will learn new skills and make decorations everyone likes.
Remember, the best holiday ideas are the ones you enjoy making. Start with easy projects, have fun, and let your creativity shine this Christmas!
You can start your holiday with easy christmas 3D print ideas. Every project helps you learn something new. Try making decorations for your christmas tree or gifts for friends. Enjoy the holiday spirit and share your creations. Wishing you a joyful christmas and a bright holiday season! 🎄
How do I choose the best filament color for holiday prints?
Pick colors that match your holiday style. Red, green, gold, and silver always look festive for christmas. Try mixing colors for fun ideas.
Can I use my 3D printer for last-minute christmas gifts?
Yes! You can print small holiday decorations or gifts in just a few hours. Quick prints make your christmas celebrations extra special.
What are some easy ways to personalize holiday 3D prints?
Add names, dates, or messages to your prints. You can paint details or glue on extras. These simple touches turn your holiday projects into unique christmas ideas.
