You want a small 3d printer that is fast and accurate. The sovol zero is a strong mini printer you can trust. It can print up to 1200mm/s and still look good. The sovol zero makes 3d printing easy, portable, and dependable. Other mini printers do not have its low price or cool features. If you want a small 3d printer that always works well, the sovol zero is the best choice.
- The Sovol Zero prints very fast, up to 1200 mm/s. It does not lose quality when printing fast. This helps you finish projects quickly.
- Its smart auto-leveling system makes setup easy. It gives you perfect first layers every time. This saves you time and effort.
- You can print with many materials. These include strong ones like PA and PC. The high-temperature nozzle and heated bed make this possible.
- The printer is small and light. You can carry it easily. It fits in small spaces but still works well.
- It has built-in Wi-Fi, Ethernet, and a live camera. You can control and watch your prints from far away. This helps you feel calm about your prints.
Sovol Zero 3D Printer Features
CoreXY Design and Speed
You want a 3d printer that is fast and accurate. The Sovol Zero uses a core XY design for quick moves and steady prints. This small core xy printer can go up to 1200mm/s. You can finish projects faster and still get good details. The core system helps stop shaking, so your models look sharp even when printing fast. You will see less ringing, so every print looks neat. The Sovol Zero is a small printer that keeps up with your needs.
Auto-Leveling and Setup
You do not need to adjust the Sovol Zero by hand. The auto-leveling uses eddy current scanning and pressure sensing. This tech checks the bed fast and fixes each spot. You get a smooth first layer every time. The Sovol Zero is easy to set up. You only put together a few parts. The auto bed leveling works quickly and keeps mistakes low. Here is how the Sovol Zero’s auto-leveling works:
Calibration Aspect |
Measurement / Statistic |
Bed Size Scanned |
Bed Scan Duration |
80 seconds |
Scanning Resolution |
0.5 microns |
Bed Leveling Error Margin |
≤ 0.02 mm |
Printing Accuracy |
±0.1 mm |
- The printer moves less than 0.02 mm off during fast moves.
- Printing stays close to ±0.1 mm for accuracy.
- Auto bed leveling saves time and makes the printer more reliable.
High-Temperature Printing
You can use many materials with the Sovol Zero. The nozzle gets as hot as 350°C, so you can print PA, PC, and other strong materials. The heated bed goes up to 120°C for better stick and steady prints. You can trust this small printer for fast printing with tough stuff. The Sovol Zero helps you try new ideas with any material.
Connectivity and Monitoring
You can control the Sovol Zero easily. The printer has Wi-Fi and Ethernet, so you can start prints from anywhere. The camera lets you watch your prints live. You can make time-lapse videos and check your prints on your phone or computer. The Sovol Zero makes it simple to watch your printer, so you always know it is working. This small printer gives you control and peace of mind.
Performance
You want your prints to look neat and sharp. The Sovol Zero gives you great print quality. It stands out among other 3d printers. Every project has high precision. The Sovol Zero keeps its position very close, at or under 0.02 mm. This means your models match your designs very well. You see smooth sides and clear edges, even when printing fast.
Performance Metric |
Sovol Zero Measurement/Description |
Positional Deviation |
≤0.02 mm, ensuring high-quality detail accuracy |
Printing Accuracy |
±0.1 mm |
Bed Scanning Resolution & Speed |
0.5 microns resolution at 1 kHz sampling rate |
Ringing Artifact Reduction |
92% reduction compared to non-CoreXY systems |
Maximum Stable Print Speed |
Maintains quality up to 1200 mm/s |
Verification Methods |
Digital calipers, micrometers, surface scanners, CT scans |
Automatic Calibration |
Z-axis offset auto-calibrated |
You can count on the Sovol Zero for pro results. Its CoreXY design and smart sensors work together. They cut down ringing artifacts by 92%. You get clean lines and smooth layers. The Sovol Zero uses digital tools to check print quality. You always get the best results. You can use many materials, like PLA or strong filaments. The Sovol Zero still gives you top quality. It makes high print quality easy for everyone.
Reliability
You need a 3d printer that works every time. The Sovol Zero is reliable, so you can focus on your ideas. It uses smart automation and sensors to spot problems early. You get live feedback and can watch your prints as they happen. The Sovol Zero checks the bed, filament, and print process for you. This means fewer failed prints and less wasted material.
Impact on Print Quality |
Dimensional Accuracy |
Precision in printed part dimensions |
Ensures parts meet design specifications |
Print Speed |
Rate of printing layers or parts |
Balances quality with efficiency |
Material Efficiency |
Material used versus waste |
Reduces cost and improves sustainability |
Automation & Sensors |
Smart cameras and sensors |
Detect and correct errors in real-time |
User Interface |
Ease of setup and control |
Reduces user errors and improves outcomes |
You can print for hours and trust it to finish. The CoreXY system keeps every move steady. The Sovol Zero’s smart features give you pro results each time. You do not have to worry about failed prints or wasted material. The Sovol Zero is your partner for steady and good prints.
Ease of Use
You want a 3d printer that is easy to use. The Sovol Zero makes every step simple, from setup to printing. You only need to put together a few parts. The auto-leveling system does the hard work for you. You do not need to adjust the bed by hand. The Sovol Zero scans and sets up everything with high precision.
You control the printer with a clear, simple interface. You can start prints, watch progress, and make changes from your phone or computer. The Sovol Zero works with Wi-Fi and Ethernet, so you stay connected. You can use many materials and switch them easily. The smart sensors and live camera help you avoid mistakes and get pro results every time.
Tip: If you want pro results without a hard learning curve, the Sovol Zero is for you. You get high print quality, steady performance, and easy controls in one small machine.
The Sovol Zero lets you create with confidence. You get speed, quality, and precision in every print. You do not need to be an expert to get pro results. The Sovol Zero makes 3d printing simple, steady, and fun.
Portability and Design
Size and Weight
You want a 3D printer that fits your space and moves easily. The Sovol Zero gives you that freedom. Its compact size lets you place it on any desk or shelf. You can carry it to your workshop, classroom, or even a friend’s house. The compact frame makes it perfect for small spaces. You do not need a big area to enjoy high-quality prints. The Sovol Zero weighs less than many other printers in its class. You can lift it without help. This compact machine gives you power and speed without taking up much room.
Tip: If you need a portable 3D printer for travel or events, the Sovol Zero is your best choice.
Build Quality
You want a printer that lasts. The Sovol Zero uses high-quality parts in every area. The strong build quality means you get a machine that stands up to daily use. The compact design does not mean weak construction. You get a sturdy frame that keeps your prints steady. The Sovol Zero uses metal rails and solid components. This gives you better quality and longer life. You can trust this compact printer to deliver great results every time.
Benefit |
Metal Linear Rails |
Smooth, precise movement |
Solid Frame |
Less shaking, better prints |
High-Quality Parts |
Long-lasting performance |
Vibration and Noise Control
You want quiet printing at home or work. The Sovol Zero uses smart design to keep noise low. The silicone damping pad absorbs vibrations. This keeps your compact printer stable, even at high speeds. You get less noise and fewer print errors. The compact build helps control sound and movement. You can print at night or in shared spaces without worry. The Sovol Zero gives you high quality and peace of mind.
- Enjoy quiet operation in any room.
- Print with confidence, knowing your compact printer stays steady.
Choose the Sovol Zero for a compact, high-quality 3D printer that fits your life and delivers every time.
Printer Comparison
Sovol Zero vs. Bambu Lab A1 Mini
You want a small 3d printer that is fast and makes good prints. The Sovol Zero is better than the Bambu Lab A1 Mini in many ways. It uses a CoreXY system with linear rails. This helps it move fast and smooth. The Sovol Zero can print up to 1200 mm/s. The A1 Mini prints slower than that. You finish your work faster and get better details with the Sovol Zero. It can also use high-temperature filaments like PA and PC. These make strong parts. The A1 Mini cannot use these materials as well. The Sovol Zero has Wi-Fi, Ethernet, and a camera for live watching. The A1 Mini does not have as many ways to connect. If you want a fast printer with more features, Sovol Zero is the best choice.
Sovol Zero vs. Prusa Mini+
You want a mini 3d printer that is easy and works well. The Sovol Zero has smart auto-leveling with eddy current scanning and pressure sensing. This gives you a perfect first layer every time. The Prusa Mini+ uses a simpler system. You spend more time setting it up. The Sovol Zero comes almost ready to use. You can start printing in just a few minutes. The Prusa Mini+ needs more building and fixing before you print. The Sovol Zero prints faster and shakes less. It also works with more types of filament. If you want to save time and get great prints, Sovol Zero is the better pick.
What Sets Sovol Zero Apart
You want a 3d printer that gives you more for your money. The Sovol Zero has special features:
- CoreXY design with linear rails for fast, accurate prints.
- Smart 3.0 auto-leveling for easy setup and fewer mistakes.
- Prints up to 350°C for tough materials.
- AC heated bed for strong stick and quick heat.
- Smart firmware with pressure advance and input shaping.
- Built-in camera for live watching and time-lapse videos.
- Comes mostly built so you can start fast.
You get a mini printer that is fast, easy, and makes good prints. The Sovol Zero makes 3d printing simple for everyone.
Note: Studies show that budget 3d printers like Sovol Zero can be as accurate and good as expensive ones. You get pro results without spending a lot.
Where Sovol Zero Falls Short
You want to know how Sovol Zero does against other top 3d printers. In tests, people printed the same parts on many small printers. They checked if the size, look, and strength were good. The Sovol Zero did very well in all tests. Your prints look like your designs and come out nice. The Sovol Zero also helps stop ringing and warping. Your models stay true to your ideas. You can trust this mini printer for daily and creative work.
Value for Money
Price and Features
You want a 3D printer that gives you a lot for your money. Sovol Zero is special because it costs less than many others. It has features that usually cost more on other printers. Many printers with the same speed and quality are more expensive. Sovol Zero keeps the price low, so you get great performance and save money.
- Sovol Zero has a CoreXY system, a high-temperature nozzle, and auto-leveling for less money than most.
- You also get Wi-Fi, Ethernet, and a built-in camera for the same price.
- The printer comes almost ready to use, so you save time and money.
- Sovol gives you a 12-month warranty and 6 months of tech support for free.
Sovol Zero Included in Price? |
CoreXY High-Speed System |
350°C Nozzle |
Auto-Leveling |
Wi-Fi & Ethernet |
Built-in Camera |
Warranty & Support |
You get all these things for one low price. Sovol Zero makes it easy for students, hobbyists, and small businesses to get a good printer.
Long-Term Investment
You want a printer that lasts and saves you money over time. Sovol Zero helps you do that. Its open-source design lets you upgrade hardware and software. You can keep your printer new without buying another one. This saves you money and gives you more value.
Sovol Zero is strong and works well, so you fix it less and print more. The warranty and support help you solve problems fast, so you do not waste time or money. Many big printers cost a lot and are expensive to own. Sovol Zero is different. You get a budget printer with a helpful community and easy upgrades.
Tip: Pick Sovol Zero if you want to save money and get good results. You get great performance, a low price, and save money in the long run.
Who Should Buy Sovol Zero
Ideal Users
You want a 3D printer that fits your busy life. The Sovol Zero works best for people who need speed, quality, and easy setup. If you are a student, you can use it for school projects and learn new skills. Teachers can use it in the classroom to show how things work. Makers and hobbyists will love the fast prints and strong parts. Engineers and designers can use it for quick prototypes and testing ideas.
You do not need to be an expert. The Sovol Zero helps beginners get started fast. You can set it up in minutes and start printing right away. If you want to try new materials, this printer lets you do that. You can print with PLA, ABS, PETG, PA, PC, and more. The Sovol Zero gives you pro results without a steep learning curve.
Tip: If you want a reliable printer that grows with your skills, Sovol Zero is your best choice.
Best Use Cases
You can use the Sovol Zero in many ways. Here are some of the best uses:
- Education: Print models for science, math, or art classes. Show students how things work.
- Prototyping: Make quick samples for new products or inventions. Test your ideas fast.
- Home Projects: Create custom parts, toys, or gifts. Fix things around the house.
- Workshops and Events: Take the Sovol Zero anywhere. Show off your designs at maker fairs or demos.
- Small Business: Make short runs of parts or products. Save money and time.
Use Case |
Why Sovol Zero Excels |
School Projects |
Fast, easy, and safe to use |
Prototyping |
High speed and strong materials |
Home Printing |
Quiet, compact, and reliable |
Events |
Portable and quick to set up |
You get a printer that fits your needs. Sovol Zero helps you create, learn, and grow. Choose Sovol Zero and unlock your ideas today.
Pros and Cons
Advantages
You get a 3D printer that stands out in many ways. The Sovol Zero brings you features that make your printing experience better and easier. Here are the top reasons you will love this printer:
- Blazing Fast Printing: You can print models at speeds up to 1200 mm/s. This means you finish projects quickly and move on to your next idea without waiting.
- CoreXY Precision: The CoreXY design gives you sharp details and smooth surfaces. Your prints look professional every time.
- Easy Setup: You spend less time building and more time printing. The Sovol Zero comes almost ready to use. You just attach a few parts and start.
- Smart Auto-Leveling: The advanced 3.0 auto-leveling system checks the bed for you. You always get a perfect first layer.
- High-Temperature Printing: You can use strong materials like PA and PC. The 350°C nozzle and 120°C heated bed open up more options for your projects.
- Real-Time Monitoring: The built-in camera lets you watch your prints live. You can check progress from your phone or computer.
- Quiet Operation: The silicone damping pad keeps noise low. You can print at home, school, or work without disturbing others.
- Reliable Performance: You get consistent results with less maintenance. The Sovol Zero works hard so you can focus on your ideas.
Tip: If you want a printer that saves you time and gives you pro results, Sovol Zero is the smart choice.
Disadvantages
Every 3D printer has areas where it could improve. The Sovol Zero is no different. You should know about these points before you decide:
- Some users notice the Sovol Zero can get noisy during fast prints. While it is quieter than many CoreXY printers, you may still hear it in a quiet room.
- The chamber lighting may not be bright enough for everyone. If you want to see every detail inside, you might need extra light.
- You have fewer upgrade options compared to printers like the Voron Zero. If you love customizing every part, this could limit you.
- The print volume is bigger than some mini printers, but it may not fit very large projects. You should check if the build size matches your needs.
Disadvantage |
User Feedback Highlights |
Noise |
Some users find it louder than expected |
Chamber Lighting |
Not bright enough for all users |
Upgrade Options |
Fewer than some competitors |
Print Volume |
May limit very large projects |
Even with these points, most users praise the Sovol Zero for its easy setup, fast speeds, and reliable prints. You get a printer that works well for daily use and creative projects.
You want the best portable 3d printer for 2025. The sovol zero stands out with its blazing speed, smart auto-leveling, and wide material support. You can print a Benchy in just 9 minutes. The sovol zero gives you pro results in a compact size. Check out these features:
Sovol Zero Specification |
Max Speed |
Build Volume |
152.4 x 152.4 x 152.5 mm³ |
Nozzle Temp |
Up to 350°C |
Connectivity |
Wi-Fi, Ethernet, Camera |
If you are a maker, student, or engineer, the sovol zero is your top pick for fast, reliable 3d printing.
How fast can you print with the Sovol Zero?
You can print at speeds up to 1200mm/s. This speed lets you finish projects quickly. You save time and get more done. The Sovol Zero keeps your prints sharp, even at high speeds.
Can you use different filaments with the Sovol Zero?
Yes! You can print with PLA, ABS, PETG, PA, PC, and more. The high-temperature nozzle gives you freedom to try new materials. You get strong, professional results every time.
Is the Sovol Zero easy to set up?
You set up the Sovol Zero in minutes. Just attach the antenna, screen, and filament sensor. The auto-leveling system handles the rest. You start printing fast without stress.
How do you monitor your prints?
You watch your prints live with the built-in camera. You check progress from your phone or computer. The Sovol Zero gives you peace of mind and control over every project.
What makes the Sovol Zero a good value?
You get advanced features like CoreXY speed, auto-leveling, and a high-temp nozzle for a low price. The Sovol Zero saves you money and delivers pro results. You invest in quality and reliability.
