zero
Sovol Zero Review Is This Tiny Powerhouse the Fastest 3D Printer for Makers
If you want the fastest 3d printer for your workshop, the Sovol Zero 3d printer stands out as a true fast machine. Sovol designed the Sovol Zero with a CoreXY system that pushes speed up to 1200mm/s while keeping prints precise. You get advanced features like automatic bed leveling and auto bed leveling, a high-temp nozzle, and a compact frame. The Sovol Zero 3d printer supports a wide range of materials and delivers professional results. You can see the Sovol Zero’s technical strengths in the table below:
Sovol Zero 3D Printer Specification
1200mm/s
Acceleration
40,000mm/s²
Leveling
Automatic bed leveling, 3.0 auto system
152.4 x 152.4 x 152.5 mm³
Material Support
PLA, PETG, TPU, PETG-CF, ABS, ASA, PA, PC
Sovol made the Sovol Zero easy to set up and reliable for daily use. You can rely on this printer’s features, leveling, and 3d performance every time.
  • The Sovol Zero 3D printer offers blazing-fast print speeds up to 1200mm/s without losing quality.
  • Its advanced auto-leveling system ensures perfect first layers and easy setup for all users.
  • You can print with many materials, including high-temperature filaments like ABS and carbon fiber.
  • The compact, sturdy design fits small spaces and keeps prints stable and precise.
  • Built-in camera and remote control features let you monitor prints from anywhere with ease.
sovol zero
Verdict
You get a compact 3d printer that delivers professional results with the Sovol Zero. Sovol designed this machine for speed, precision, and reliability. The zero uses a CoreXY motion system, which allows you to print at speeds up to 1200mm/s. You can expect smooth, accurate prints even when you push the limits. The advanced auto-leveling system ensures your first layer sticks every time. Sovol includes a high-temp nozzle, so you can work with a wide range of materials. The zero’s robust frame and linear rails keep your prints stable and consistent.
Key Performance Highlights:
  1. CoreXY design enables fast, precise 3d printing up to 1200mm/s
  2. Advanced 3.0 auto-leveling system for easy, accurate setup
  3. Supports PLA, PETG, TPU, PETG-CF, ABS, ASA, PA, and PC
  4. Compact build volume (152.4 x 152.4 x 152.5 mm³) fits small spaces
  5. High-temp nozzle (up to 350°C) and heated bed (up to 120°C) expand material options
  6. Open-source firmware and Wi-Fi/Ethernet connectivity for customization and remote control
  7. Built-in camera for real-time monitoring and time-lapse recording
You will find the Sovol Zero stands out in the crowded 3d printer market. Sovol delivers a machine that balances speed, quality, and user-friendly features. The zero’s performance and reliability make it a top choice for makers who want results fast.
Who It’s For
You should consider the Sovol Zero if you value speed and precision in your 3d projects. This printer suits makers, engineers, and hobbyists who need a reliable tool for rapid prototyping or small-batch production. If you work with advanced materials or want a compact printer for a limited workspace, the zero fits your needs. Sovol designed the zero for users who want professional results without a steep learning curve. You can set up the printer quickly and start printing high-quality parts right away. The Sovol Zero also appeals to educators and creative professionals who need a versatile, high-performance 3d printer.
First Impressions
Unboxing
When you open the Sovol Zero box, you notice the attention to detail right away. Sovol packs the 3d printer securely, so every part arrives in perfect condition. The compact size stands out immediately. You can lift the zero with one hand, making it ideal for small workspaces or classrooms. Sovol includes everything you need to get started, including tools, a sample filament, and a quick-start guide. You do not have to search for extra parts or accessories.
The robust construction of the zero impresses you from the start. Sovol uses high-quality metal for the frame, which gives the printer a solid feel. The CoreXY design and linear rails look precise and well-engineered. You can see that Sovol built this 3d printer for both speed and durability.
Tip: Keep the packaging for future transport or storage. Sovol’s custom foam protects the zero during moves.
Setup
You will find the Sovol Zero incredibly easy to set up. Sovol designed the printer so you only need to attach the external antenna, the screen, and the filament sensor. The process takes just a few minutes, even if you are new to 3d printing. The quick-start guide walks you through each step with clear instructions and helpful images.
Sovol makes sure you do not waste time on complicated assembly. The zero arrives mostly pre-assembled, so you can focus on printing instead of building. You connect the power, load the filament, and follow the on-screen prompts. The auto-leveling system calibrates the bed for you, ensuring a perfect first layer every time.
You will appreciate how Sovol combines a compact footprint with a sturdy build. The zero fits easily on a desk or shelf, but it feels strong and stable during operation. Sovol’s thoughtful design means you get a 3d printer that is both easy to set up and ready for high-speed projects right out of the box.
Sovol Zero 3D Printer Design
sovol zero
Compact Build
You will notice the Sovol Zero 3D printer stands out as a compact Core XY 3D printer built for tight spaces. Sovol designed the zero to fit easily on a desk, shelf, or in a classroom without crowding your workspace. The build volume measures 152.4 x 152.4 x 152.5 mm, which gives you enough room for most 3D projects while keeping the footprint small. You can move the Sovol Zero with one hand, making it ideal for makers who need flexibility or have limited space.
The CoreXY system in the Sovol Zero 3D printer uses two motors to reduce moving mass. This design allows for faster, more accurate printing and helps maintain a tidy, efficient appearance. Sovol manages cables and parts neatly, so you get a clean look and easy access to every feature. The printer ships preassembled, so you spend less time setting up and more time printing. You will appreciate how Sovol combines automatic bed leveling, a fully enclosed chamber, and a built-in camera in such a compact package.
Note: The Sovol Zero 3D printer’s smart use of space and thoughtful design make it a top choice for anyone needing a compact yet capable 3D printer.
Durability
Sovol built the zero to last. You get a strong build quality with a sturdy metal frame that resists vibration and keeps your prints stable at high speeds. Full linear rails on all axes ensure smooth, precise motion, even during fast printing. The AC heated bed reaches up to 120°C, supporting advanced materials and reducing warping. Sovol includes silicone damping pads to absorb vibrations, which helps maintain print quality over time.
The Sovol Zero 3D printer features a high-temperature nozzle capable of reaching 350°C. This lets you print with advanced filaments like PA, PC, and carbon fiber composites. The fully enclosed design maintains stable temperatures and protects your prints from drafts or dust. Automatic bed leveling combines eddy current scanning with pressure sensing, so you always get reliable calibration and consistent results.
You can trust Sovol’s attention to detail and robust engineering. The zero delivers reliable performance, print after print, making it a dependable choice for makers who demand quality and durability from their 3D printer.
Speed and Performance
You want a 3D printer that delivers fast print speeds without sacrificing quality. The Sovol Zero 3D printer stands out for its impressive speeds, reaching up to 1200mm/s with a maximum acceleration of 40,000mm/s². Sovol uses a CoreXY motion system, which reduces moving mass and allows for rapid, precise movements. This design gives you the ability to produce speedy prototypes and finished parts much faster than traditional 3D printers.
Take a look at how the Sovol Zero compares to other printers in real-world performance:
Printer
Max Speed (mm/s)
Typical Benchy Print Time
Focus
Sovol Zero
1200
~9 minutes
Voron Zero
250
~25 minutes
Precision
You can print a standard Benchy model in about 9 minutes, which is more than twice as fast as many competitors. The Sovol Zero 3D printer also maintains positional accuracy of ≤0.02 mm at high speed, so you do not have to trade speed for precision. Input Shaping and Pressure Advance technologies work together to reduce ringing and maintain smooth extrusion, even when you push the printer to its limits.
Note: The Sovol Zero’s fast print speeds make it ideal for rapid prototyping, classroom demonstrations, or any project where time matters.
You expect excellent quality at speed, and the Sovol Zero 3D printer delivers. Sovol engineered the zero with XYZ full linear rails, which ensure smooth, stable motion and precise layer placement. The advanced auto-leveling system combines eddy current scanning and pressure sensing, so you always get a perfect first layer. This technology helps you achieve consistent print quality, even during long or complex jobs.
Here are some key performance metrics that highlight the Sovol Zero’s print quality and accuracy:
Performance Metric
Result/Value
Maximum Acceleration
40,000 mm/s²
Maximum Print Speed
Up to 700 mm/s
Positional Accuracy
Vibration Reduction
92% less than non-corexy setups
Frame Strength
180% stronger than standard aluminum frames
Print Speed Improvement
120% faster than MK4S system
Extrusion Rate
35 mm³/s for all layer sizes
You will notice sharp details, smooth surfaces, and minimal artifacts, even when printing at high speed. Input Shaping and Pressure Advance help prevent ghosting and over-extrusion, so your models look clean and professional. The Sovol Zero 3D printer supports a wide range of materials, including PLA, PETG, TPU, ABS, ASA, PA, and PC, so you can tackle both simple and advanced projects with confidence.
Reliability
You need a printer that offers reliable performance over time. Sovol designed the Sovol Zero 3D printer with durability and stability in mind. The CoreXY frame provides a solid structure that reduces wear and supports long-term use. XYZ linear rails ensure smooth, precise motion, while silicone damping pads absorb vibrations and help maintain print quality.
Here are some highlights of the Sovol Zero’s reliability and long-term performance:
  • The CoreXY frame stays solid, reducing wear and maintaining accuracy.
  • XYZ linear rails deliver smooth, precise motion for every print.
  • Silicone damping pads absorb vibrations, improving stability and print quality.
  • Automatic bed leveling with eddy current scanning and pressure sensing ensures consistent first layers.
  • Users report very few jams or errors, even after many hours of printing.
  • High print speeds do not compromise precision or quality.
  • Customer satisfaction is high, with 98% positive feedback.
  • Sovol’s active community and responsive support help you maintain your printer’s performance.
With proper maintenance, you can expect thousands of hours of reliable printing from the Sovol Zero 3D printer. The zero’s robust construction and advanced features give you confidence in every project, whether you print a single prototype or run continuous production.
Experience
Interface
You interact with the Sovol Zero through a responsive touchscreen. The menu layout feels intuitive, so you can access print settings, calibration tools, and monitoring features with just a few taps. Sovol designed the interface to minimize confusion, even if you are new to 3d printing. You can start, pause, or stop a print job quickly. The built-in camera lets you monitor progress in real time, which adds convenience and peace of mind. You also have the option to connect the printer via Wi-Fi or Ethernet, giving you remote control from your computer or mobile device.
Tip: Use the Obico integration for time-lapse videos and remote monitoring. This feature helps you keep track of long prints without staying in the workshop.
Maintenance
You will find that maintaining the Sovol Zero is straightforward. Sovol engineered the printer for easy access to key components. The double-sided PEI build plate pops off for quick cleaning or part removal. The auto-leveling system reduces the need for manual adjustments, saving you time and effort. You can swap nozzles easily, which helps when switching between standard and high-temperature materials. The air filtration system keeps the workspace cleaner by filtering out particles and odors during 3d printing. Sovol provides clear maintenance instructions, so you can keep your zero running smoothly with minimal downtime.
  • Clean the build plate after each print for best adhesion.
  • Check the filament path and extruder regularly to prevent jams.
  • Replace the air filter as recommended for optimal performance.
Noise
You want a 3d printer that does not disrupt your workspace. The Sovol Zero operates quietly, thanks to its CoreXY design and silicone damping pads. These features reduce vibration and mechanical noise, making the printer suitable for home offices or classrooms. In environments with good sound insulation, such as those with partition walls rated at 50 dB Weighted Standardized Level Difference, you will notice that the Sovol Zero blends into the background. This level of noise reduction surpasses many national standards for living spaces, so you can focus on your projects without distraction.
Note: The Sovol Zero’s quiet operation makes it a strong choice for shared spaces or late-night printing sessions.
Pros and Cons
Strengths
You will find that the Sovol Zero offers a range of strengths that set it apart from other compact 3D printers.
  • The CoreXY design gives you blazing-fast print speeds. You can finish projects quickly without losing quality.
  • The advanced auto-leveling system ensures that every print starts with a perfect first layer. You do not need to worry about manual calibration.
  • The zero supports a wide variety of materials, including high-temperature filaments. This flexibility lets you tackle both simple and advanced projects.
  • The robust metal frame and full linear rails provide stability. You get consistent results, even at high speeds.
  • The built-in camera and remote monitoring features help you keep track of your prints from anywhere.
  • The zero’s compact size fits easily into small workspaces, classrooms, or home offices.
  • The air filtration system improves safety by reducing odors and particles during printing.
Tip: You can rely on the zero for both rapid prototyping and high-quality finished parts. The printer’s design focuses on delivering professional results every time.
Weaknesses
You may notice that the Sovol Zero’s compact build volume limits the size of your projects. If you plan to print large models, you might need to split them into smaller parts. The zero’s advanced features require some learning if you are new to 3D printing. You should take time to explore the interface and settings to get the best results. Some users may prefer a larger touchscreen or more physical controls, but the current setup remains user-friendly.
Note: The zero’s strengths in speed, material support, and print quality outweigh these minor limitations for most makers.
Sovol Zero vs Competitors
Speed Comparison
When you compare the Sovol Zero 3D printer to other compact 3D printers, you see a clear difference in speed. Many desktop printers in this class reach only 200-300mm/s. The Sovol Zero 3D printer pushes the limit with a maximum speed of 1200mm/s. You can print a standard Benchy in about 9 minutes. Competing models, such as the Voron Zero, often take more than 20 minutes for the same task.
The CoreXY motion system in the Sovol Zero 3D printer gives you fast, precise movement. You get high acceleration and smooth transitions, which means you finish projects faster. Input Shaping and Pressure Advance technologies help you keep print quality high, even at top speed. If you want rapid prototyping or need to produce many parts quickly, the Sovol Zero stands out as the fastest affordable mini core xy option.
Tip: If speed matters most in your workflow, the Sovol Zero 3D printer gives you a real advantage over other compact printers.
Value
You want a 3D printer that delivers both performance and value. The Sovol Zero 3D printer offers advanced features, such as a high-temp nozzle, automatic bed leveling, and a built-in camera, at a price point that stays accessible for most makers. Many competitors charge more for similar features or require extra upgrades.
With the Sovol Zero, you get a robust metal frame, full linear rails, and support for a wide range of materials. You do not need to sacrifice quality for affordability. The Sovol Zero 3D printer gives you professional results, reliable operation, and user-friendly controls. You save time and money with fewer failed prints and less manual calibration.
  • You get more features for your investment.
  • You enjoy high-speed printing without losing accuracy.
  • You benefit from Sovol’s active community and support.
When you look for the best balance of speed, quality, and cost, the Sovol Zero 3D printer leads the pack.
Bottom Line
You get a true tiny powerhouse with the sovol zero. This 3d printer delivers unmatched speed and reliable print quality. The sovol zero stands out for its CoreXY design, advanced auto-leveling, and support for high-temp materials. If you want a fast 3d printer for rapid prototyping, advanced materials, or a small workshop, the sovol zero fits your needs. Consider your project size and workspace before choosing your next 3d printer. Have you tried the sovol zero? Share your experience in the comments!
How fast can you print with the Sovol Zero?
You can reach speeds up to 1200mm/s with the Sovol Zero. The CoreXY system and advanced motion control let you finish prints much faster than most compact 3D printers.
What materials can you use with the Sovol Zero?
You can print with PLA, PETG, TPU, PETG-CF, ABS, ASA, PA, and PC. The high-temp nozzle and heated bed support both standard and advanced filaments.
Does the Sovol Zero require manual bed leveling?
No. The Sovol Zero features a 3.0 auto-leveling system. You get accurate, hands-free calibration every time you start a print.
Can you monitor prints remotely?
Yes. The built-in camera and Wi-Fi connectivity let you watch your prints in real time. You can also create time-lapse videos using Obico integration.
Is the Sovol Zero suitable for beginners?
Absolutely. You get a mostly pre-assembled printer, a clear touchscreen interface, and easy setup. The Sovol Zero works well for both new users and experienced makers.
