By Cathy Lim16 min read
SV07 vs SV07 Plus: Discover the Key Differences
Compare Sovol SV07 vs SV07 Plus 3D printers. Discover differences in build size, features, and pricing to choose the best option for your printing needs.
Key Features Compared
Explore the differences between Sovol SV07 and SV07 Plus.
Features
Sovol SV07 3D Printer
Sovol SV07 Plus 3D Printer
220 x 220 x 250 mm
300 x 300 x 350 mm
Up to 500 mm/s
Up to 500 mm/s
Cooling System
Triple fan cooling
Enhanced triple cooling
Auto-Leveling
Standard auto-leveling
25-point auto-leveling
Power Supply
350W MeanWell
600W MeanWell
Price
$259
$259
Touchscreen Interface
5-inch touchscreen
5-inch touchscreen
Filament Compatibility
PLA, PETG, TPU, carbon fiber
When comparing the Sovol SV07 vs SV07 Plus, there are important differences to consider.
  • The SV07 has a smaller build space, making it ideal for small projects.
  • In contrast, the SV07 Plus offers a larger workspace, which is better suited for large designs.
  • Both models are stable and precise, but the Plus enhances the experience with improved cooling and power features.
  • They both utilize Klipper firmware for fast and steady printing.
  • Additionally, the prices vary, allowing you to choose based on your budget.
Understanding these differences between the SV07 vs SV07 Plus will help you select the right printer for your needs.
  • The Sovol SV07 is great for beginners. It is small and easy to use, perfect for tiny projects.
  • The Sovol SV07 Plus has a bigger build area. It works well for experts or big projects needing more space.
  • Both printers use Klipper firmware for fast printing. The SV07 Plus has better cooling and auto-leveling for improved results.
  • Think about your budget: the SV07 costs $259 and is cheaper. The SV07 Plus, also $259 during sales, has extra features for a bit more money.
  • Decide based on your needs: pick the SV07 for simple tasks or the SV07 Plus for bigger, harder designs.
Sovol SV07 Overview
Features and Specifications
The Sovol SV07 is a flexible and efficient 3D printer. It works well for both beginners and experts. Its build size is 220 x 220 x 250 mm, which is great for small or medium projects. The printer can reach a top speed of 500 mm/s, making it fast. For better results, a speed of 250 mm/s is recommended. This keeps prints both quick and high-quality.
A standout feature of the SV07 is its Klipper firmware. This software allows fast printing while staying stable. The 5-inch touchscreen makes it easy to use and control. You can also upload files remotely using its built-in Wi-Fi, which is very convenient.
The SV07 has a dual gear direct drive extruder for accurate filament feeding. Its all-metal hotend heats up to 300°C, so it works with materials like PLA, PETG, TPU, and carbon fiber. The auto-leveling system uses a sensor to ensure the print bed is even. A filament sensor stops the print if the filament runs out or breaks.
The printer has three fans to cool prints, improving quality and finish. It runs quietly because of its silent mainboard and special drivers. The 350W MeanWell power supply ensures it works well, even during long prints.
Target Audience
The Sovol SV07 is great for people who want a reliable and affordable 3D printer. Beginners will like its easy features, such as auto-leveling and a touchscreen. These make it simple to start printing. Hobbyists will enjoy its small size and ability to use different materials. It’s perfect for creative projects without needing much space.
Professionals may use it as a second printer or a budget-friendly option. Its speed and precision are good for prototypes and small production jobs. At $259, it’s a great choice for quality without spending too much.
Sovol SV07 Plus Overview
The Sovol SV07 Plus has features for both new and skilled users. Its large build size of 300 x 300 x 350 mm lets you print big models or many items at once. This makes it great for large projects or producing multiple prints.
It uses Klipper firmware, allowing fast printing up to 500 mm/s. For better accuracy, printing at 250 mm/s is suggested. The all-metal hotend heats up to 300°C, so it works with materials like PLA, PETG, TPU, and carbon fiber. The dual gear extruder feeds filament smoothly, which helps with detailed designs.
The printer has a 25-point auto bed leveling system for even first layers. Its triple cooling system improves print quality by quickly cooling layers. The flexible PEI platform makes removing prints easy and quick. You can transfer files using USB, Type-C, or Wi-Fi. The 5-inch touchscreen is simple to use and control.
Specification
Details
300 x 300 x 350 mm
Max – 500 mm/s, Recommended – 250 mm/s
Max Temperature
300°C
Bed Leveling
25-point auto leveling
Cooling
Triple Cooling
Connectivity
USB, Type-C, Wi-Fi
Interface
5-inch Klipper Screen
PLA, ABS, PETG, TPU, Nylon, Other
Price
$309-379
Target Audience
The Sovol SV07 Plus is made for people who want a strong and flexible 3D printer. Beginners will like its easy-to-use features, like auto-leveling and the touchscreen. These make printing simple and fun.
Professionals will enjoy the large build space and fast speeds. It’s great for making prototypes or small production runs. It also works with advanced materials like carbon fiber and TPU, giving more creative options. Hobbyists will love its accuracy and ability to make detailed models or useful parts.
People like the Sovol SV07 Plus for its big print size, Wi-Fi, and price. Some users mention small issues like noise or cable setup. Even with these, it’s still a favorite for its mix of performance and cost.
SV07 vs SV07 Plus: Side-By-Side Comparison
The Sovol SV07 and SV07 Plus have different build sizes. The SV07 has a smaller space of 220 x 220 x 250 mm. This size is great for small or medium projects. It’s perfect for hobbyists or people with little room. The SV07 Plus, however, has a bigger space of 300 x 300 x 350 mm. This larger area lets you print bigger models or many items at once. It’s ideal for professionals or those working on large projects.
Model
Build Volume (mm)
Sovol SV07
220 x 220 x 250
Sovol SV07 Plus
300 x 300 x 350
The table shows the size difference between the two printers. If you need more space, pick the SV07 Plus. For smaller tasks, the SV07 is a good choice.
Structural Stability
Both printers are strong and stable for accurate printing. The SV07 has a solid frame that reduces shaking while printing. This helps it make high-quality prints, even when printing fast.
The SV07 Plus is even stronger. Its design handles bigger prints and faster speeds better. It also has a large cooling fan behind the print head. This fan keeps the temperature steady, helping prints stay detailed and in shape. It’s great for complex designs.
Firmware and Software
Both printers use Klipper firmware, which is fast and efficient. They can print up to 500 mm/s, but 250 mm/s is better for accuracy. The firmware has features like Input Shaping and Pressure Advance. These reduce shaking and improve how the filament is used.
Both printers have a 5-inch touchscreen for easy control. You can upload files using Wi-Fi, USB, or Type-C. The SV07 Plus has extra features, like a 25-point auto bed leveling system. This system makes sure the print bed is even, which helps with perfect first layers.
Printing Speed and Quality
The Sovol SV07 and SV07 Plus are both fast printers. The SV07 can print up to 500 mm/s, which is great for quick jobs. For better accuracy, printing at 250 mm/s is recommended. The SV07 Plus also prints at these speeds but handles bigger, more detailed designs better.
Tests show the SV07 Plus is faster for tough prints. A hard test print took only two hours to finish. Another complex model, which used to take 18 hours, was done in 9 hours with Klipper firmware. This shows how the SV07 Plus keeps speed without losing quality.
Both printers make high-quality prints. They have advanced cooling and precise filament feeding. The SV07 has three fans to cool layers, giving smooth and shiny results. The SV07 Plus adds a bigger fan behind the print head. This keeps the temperature steady for detailed designs. Whether you need speed or detail, both printers perform well.
Ease of Use
The Sovol SV07 and SV07 Plus are easy to use. The SV07 has a 5-inch touchscreen that makes settings simple to adjust. Its auto-leveling system ensures the print bed is even, saving time and improving first layers.
The SV07 Plus improves on this with a 25-point auto-leveling system for more accuracy. You can upload files using Wi-Fi, USB, or Type-C, making it flexible for different needs. Its flexible PEI platform makes removing prints quick and easy.
Both printers are quiet because of their silent mainboards and special drivers. Whether you're new to 3D printing or experienced, these printers are fun and simple to use.
Pricing
The Sovol SV07 and SV07 Plus are priced fairly for their features. The SV07 costs $259, making it a good choice for hobbyists or those on a budget. It still offers great features like Klipper firmware and Wi-Fi.
The SV07 Plus, with its bigger build space and extra features, costs $259 during sales, down from $329. This makes it a great option for professionals or people needing a printer for big projects.
Both printers give you good performance for the price, making them worth the investment.
Pros and Cons of Sovol SV07 and SV07 Plus
Advantages of Sovol SV07
The Sovol SV07 has many benefits, especially for beginners and those on a budget.
  • Affordable Price: At $259, it’s a great deal for its features. It’s one of the best low-cost 3D printers.
  • Ease of Use: The auto bed leveling system makes starting prints easy. It saves time and effort.
  • Fast Printing Speeds: It can print up to 500 mm/s. This means quick results without losing quality.
  • Klipper Firmware: The pre-installed Klipper firmware improves performance and keeps prints steady.
  • Material Compatibility: The all-metal hotend works with PLA, PETG, TPU, and carbon fiber.
  • Compact Design: Its smaller size (220 x 220 x 250 mm) is great for hobbyists or small spaces.
Advantages
Details
Budget-Friendly
Affordable price for beginners
High-Speed Printing
Up to 500 mm/s
Klipper Firmware
Pre-installed for better performance
Material Versatility
Supports multiple filament types
Disadvantages of Sovol SV07
The Sovol SV07 is great, but it has some downsides.
  • Limited Build Volume: Its smaller size isn’t good for big projects.
  • Basic Cooling System: The cooling system works but lacks advanced features like the SV07 Plus.
These limits make the SV07 better for small tasks or as a starter printer.
Advantages of Sovol SV07 Plus
The Sovol SV07 Plus improves on the SV07 with extra features for advanced users.
  • Larger Build Volume: Its 300 x 300 x 350 mm space lets you print bigger models or several items at once.
  • Enhanced Cooling System: The triple fan design keeps temperatures steady for better prints.
  • Advanced Auto-Leveling: The 25-point auto-leveling system ensures even first layers on uneven surfaces.
  • Improved Extruder: The dual-gear extruder easily handles flexible materials like TPU.
  • Powerful Performance: The 600W MeanWell power supply keeps it stable during long prints.
Specification
300 x 300 x 350 mm
Cooling System
Triple cooling fan design
Auto Bed Leveling
25-point with inductive sensor
Extruder
Dual-gear direct drive
The SV07 Plus is ideal for professionals or hobbyists needing a printer for big or detailed projects.
Disadvantages of Sovol SV07 Plus
The Sovol SV07 Plus has great features, but there are some downsides. These might affect whether it suits your needs.
  • Larger Size: The SV07 Plus can handle big projects with its large build space. But its bigger frame takes up more room. If your workspace is small, it might be hard to fit.
  • Higher Power Use: The 600W power supply keeps the printer steady during long prints. However, it uses more electricity than smaller printers. If saving energy matters to you, think about this.
  • Challenging for Beginners: The SV07 Plus is beginner-friendly, but its advanced features can be tricky. Learning the 25-point auto-leveling system and Klipper firmware may take time. Practice helps you get the best results.
Tip: Start with simple projects to learn how the printer works before trying harder designs.
  • Longer Setup Time: Setting up the SV07 Plus takes effort. Its larger size and extra features mean assembly and calibration might take longer. This is normal for many 3D printers.
These points show why you should think about your space, energy use, and skill level before buying the SV07 Plus. Knowing these details will help you decide if this printer fits your needs.
Use Case Recommendations
Best for Beginners
If you're new to 3D printing, the Sovol SV07 is a great pick. Its small size and simple features make it beginner-friendly. The auto-leveling system keeps the print bed even, so you don’t need to adjust it yourself. The 5-inch touchscreen is easy to use, helping you start prints quickly.
The SV07’s smaller build space of 220 x 220 x 250 mm is perfect for learning. You can try different materials like PLA, PETG, and TPU. Its all-metal hotend heats up to 300°C, making it versatile. The printer is quiet and compact, fitting well in small spaces at home.
Price matters for beginners, and the SV07 costs just $259. It offers great value with important features included. The pre-installed Klipper firmware ensures smooth and fast printing. This helps you create quality prints from the start. Whether you’re making simple shapes or trying harder designs, the SV07 is a fun way to begin 3D printing.
Best for Professionals
For professionals, the Sovol SV07 Plus is a strong and flexible choice. Its large build space of 300 x 300 x 350 mm is great for big projects. You can make prototypes, working parts, or multiple items at once. The SV07 Plus has advanced features for precision and reliability.
The dual-gear extruder feeds filament smoothly, even flexible ones like TPU. Its 25-point auto-leveling system ensures the print bed is perfectly even. The triple cooling fans and high-flow hotend keep temperatures steady, improving print quality.
Here are some key professional features:
Dimensional Accuracy
Ensures prints match the original design.
Surface Finish
Creates smooth and neat outer layers.
Layer Adhesion and Strength
Makes strong prints with good layer bonding.
The SV07 Plus is also fast, printing up to 500 mm/s. This speed helps finish detailed projects quicker without losing quality. Its 600W power supply keeps it stable during long prints, making it reliable for tough tasks.
If you’re a professional needing speed, accuracy, and flexibility, the SV07 Plus is a great option.
Best for Large-Scale Printing
For large-scale printing, the Sovol SV07 Plus is the best choice. Its big build space of 300 x 300 x 350 mm lets you print large models or many parts at once. This is ideal for architects, engineers, or hobbyists working on big ideas.
The SV07 Plus has advanced features like a 25-point auto-leveling system and triple cooling fans. These ensure consistent quality for large prints. The high-flow hotend, which heats up to 300°C, works with materials like PLA, PETG, and carbon fiber. This makes it great for complex or functional designs.
Its sturdy frame and 600W power supply provide stability for long printing sessions. The SV07 Plus handles big projects without losing accuracy or strength. It delivers high-quality results quickly, making it a valuable tool for large-scale 3D printing.
If you need to print big designs or handle batch jobs efficiently, the SV07 Plus has the features and performance to meet your needs.
Best for Budget Buyers
If you want a 3D printer that’s affordable and works well, the Sovol SV07 and SV07 Plus are great options. Both models have advanced features at reasonable prices, making them perfect for saving money.
The Sovol SV07 costs $259 and is one of the cheapest in its class. Even with its low price, it still delivers good quality and performance. It has a small build space of 220 x 220 x 250 mm, which is ideal for smaller projects. The Klipper firmware helps it print quickly and accurately. Its auto-leveling system makes setup easy. You can also use different materials like PLA, PETG, and TPU for various projects.
The Sovol SV07 Plus, on sale for $259 (regularly $329), offers a bigger build space of 300 x 300 x 350 mm. This is great for larger models or printing multiple items at once. It has advanced features like a 25-point auto-leveling system and triple cooling fans, which improve print quality. Its 600W power supply keeps it stable during long prints.
Here’s a simple comparison:
Sovol SV07
Sovol SV07 Plus
Price
$259
$259
220 x 220 x 250 mm
300 x 300 x 350 mm
Auto-Leveling
Standard
25-point advanced
Cooling System
Triple fans
Triple fans with larger fan
Power Supply
350W
600W
If you’re new to 3D printing or have a small budget, the SV07 is a great choice. Its small size and easy-to-use features make it perfect for beginners. If you need more space and advanced features, the SV07 Plus is a better option, especially during sales.
Tip: Think about your project size and workspace before choosing. The SV07 is best for smaller tasks, while the SV07 Plus handles bigger, harder projects.
Both printers are praised for being affordable and reliable. Users love how easy they are to use and the high-quality prints they produce. Whether you pick the SV07 or SV07 Plus, you’ll get a printer that’s worth the money.
Picking between the Sovol SV07 and SV07 Plus depends on your needs. The SV07 is cheaper and smaller, great for beginners or hobbyists with little space. Its compact size and ability to use different materials make it perfect for creative projects. Meanwhile, the SV07 Plus is better for bigger tasks. It has advanced features like a 25-point auto-leveling system and triple cooling fans. These features make it precise and reliable for professionals or complex designs.
Think about these points before choosing:
  1. Printing Speed: Both printers can print up to 500 mm/s quickly.
  2. Build Volume: The SV07 is for small prints, while the SV07 Plus handles larger models.
  3. Material Compatibility: Both work with many filament types, making them versatile.
If you want something affordable and simple, pick the SV07. For bigger projects and advanced features, the SV07 Plus is a better option. Choose the one that fits your goals and space best.
What are the main differences between the Sovol SV07 and SV07 Plus?
The SV07 has a smaller build volume (220 x 220 x 250 mm) and is compact. The SV07 Plus offers a larger build space (300 x 300 x 350 mm) and advanced features like a 25-point auto-leveling system and triple cooling fans. Choose based on your project size.
Tip: If you need to print large models, the SV07 Plus is the better choice.
Can beginners use the Sovol SV07 Plus?
Yes, beginners can use the SV07 Plus. Its auto-leveling system and touchscreen make it user-friendly. However, its advanced features may require some learning. Start with simple projects to get comfortable with the printer.
What materials can these printers handle?
Both printers support materials like PLA, PETG, TPU, and carbon fiber. Their all-metal hotends heat up to 300°C, making them versatile for various projects. You can experiment with flexible or rigid filaments depending on your design needs.
How fast can these printers print?
Both models can print at speeds up to 500 mm/s. For better accuracy and quality, printing at 250 mm/s is recommended. The Klipper firmware ensures smooth and stable performance even at higher speeds.
Which printer is better for small spaces?
The Sovol SV07 is better for small spaces. Its compact design and smaller build volume make it ideal for hobbyists or users with limited workspace. The SV07 Plus requires more room due to its larger frame.
Note: Measure your workspace before deciding which printer to buy.
Read nextHow to Optimize 3D Printing Tolerances for Better Results
