You know how annoying it is when your 3D prints look bad. Prints can be rough, bubbly, or weak. Moisture gets into filament and causes popping sounds. It also makes bubbles and weak prints. The sh02 filament dryer from Sovol helps fix these problems fast. It dries filament quickly. It has smart safety features. The controls are easy to use. This filament dryer makes printing easy. You can get smooth, strong prints every time. It works for everyone, even if you are new.
Visual Defect |
Bubbling |
Tiny bubbles show up from steam in the filament |
Rough Surfaces |
Uneven flow makes prints look spotty |
Weak Structure |
Moisture makes prints break more easily |
- Moisture in filament can cause problems like bubbles, weak layers, and jams. Keep filament dry to get better prints.
- The SH02 Filament Dryer removes moisture fast. It heats up to 70°C in only 25 minutes. This saves you time and makes prints look better.
- The SH02 has simple controls. You can set the right temperature and humidity for each filament type. This helps dry filament the best way.
- The dryer has two chambers. You can dry two filament types at once. This makes drying faster.
- Using the SH02 often keeps filament in good shape. Your prints will be smoother and stronger. You will have fewer failed projects.
Common Printing Problems from Moist Filament
Stringing and Oozing Issues
Have you ever noticed thin, messy strands hanging off your 3D prints? That’s called stringing. Oozing happens when extra material leaks out of the nozzle and sticks to your project. Both problems often come from moisture in your filament. When filament absorbs water from the air, steam forms inside during printing. This steam pushes out bubbles and weak spots. You see stringing and oozing because wet filament can’t flow smoothly. Here’s what happens:
- Moisture gets trapped inside filament.
- Steam forms when the filament heats up.
- Bubbles pop out, causing stringing and oozing.
- Your print looks messy and uneven.
If you want clean prints, you need dry filament. Moisture is the hidden troublemaker.
Weak Layers and Poor Adhesion
You want your prints to be strong, right? Moist filament can ruin that. When you use wet filament, steam bubbles form between layers. These bubbles create empty spaces. The layers don’t stick together well, so your print can break or peel apart. Poor adhesion means your project won’t last. Here’s why moisture causes weak layers:
- Steam bubbles stop layers from bonding.
- Empty spaces appear inside your print.
- Layers separate easily, leading to weak adhesion.
- Your print might snap or fall apart.
Dry filament helps layers bond tightly. You get solid, sturdy prints every time.
Brittle Prints and Jams
Brittle prints break with just a little pressure. Moisture in filament makes prints fragile. The steam inside causes cracks and weak spots. Sometimes, wet filament even jams your printer. You hear popping sounds, and the nozzle gets blocked. That means you have to stop and fix things. Here’s what you might notice:
- Prints snap or crumble when you touch them.
- Filament jams inside the printer.
- You hear popping or crackling noises.
- Your project doesn’t finish because of jams.
If you keep your filament dry, you avoid these problems. You get smooth, strong prints without jams or breaks.
How the SH02 Filament Dryer Works
Moisture Removal Technology
You want your filament dry and ready to use, right? The sh02 filament dryer uses smart technology to remove moisture. It heats up fast and can reach 70°C in only 25 minutes. This means you do not have to wait long to start printing. The 150W PTC heater gives strong and even heat. Your filament dries the same way every time.
The sh02 filament dryer is special because it has a 360° heating system. This system warms your filament from all sides. Every part of the filament gets dry. The triple ring sealing keeps air and water out. Your filament stays safe, even if you leave it in the box for days.
Here are the reasons why the sh02 filament dryer works so well:
- You can pick a temperature from 40-70°C for different filaments
- The 150W PTC heater dries fast and saves energy
- Triple ring sealing keeps moisture away for a long time
- 360° heating dries every part of the filament
- It dries filament in just 6-8 hours
You can see how this technology is better than others in the table below:
SH02 Filament Dryer |
Creality Space Pi |
Heating |
360° heating for uniform heat distribution |
360-degree air circulation |
Moisture Protection |
Triple ring sealing for enhanced protection |
Standard sealing |
Drying Efficiency |
Efficient drying of both spools simultaneously |
Slight variations in airflow distribution |
Noise Levels |
Reduced noise due to sealing |
Not specified |
Temperature and Humidity Control
You can control the temperature and humidity with the sh02 filament dryer. The big LCD touchscreen lets you choose the best settings for your filament. You can use a one-key preset for common materials or set your own temperature between 40°C and 70°C. You can also pick how long to dry, from 0 to 98 hours. This helps you get the best results for every print.
The sh02 filament dryer has two heating chambers. Each chamber dries one spool at a time. Each chamber checks its own humidity. You can dry PLA in one chamber and ABS in the other at the same time. This saves you time and makes printing easier.
Here is a quick look at which filaments work with the sh02 filament dryer:
Filament Type |
PLA |
Yes |
TPU |
Yes |
PETG |
Yes |
ABS |
Yes |
ASA |
Yes |
PVA |
Yes |
PC |
Yes |
PA |
Yes |
PP |
Yes |
The sh02 filament dryer keeps your filament at the right humidity. This means your filament will not get brittle. Your prints will be smoother and stronger.
Tip: Use the auto dehumidification feature to keep your filament dry even when you are not printing. The sh02 filament dryer will check the humidity and dry your filament when needed.
Safety and User-Friendly Features
You want a filament dryer that is safe and simple to use. The sh02 filament dryer is both. It has PTC overheat protection, fan rotation checks, and real-time temperature checks. These features keep the dryer safe, so you do not have to worry.
The design is easy for anyone to use. The 3.9-inch LCD touchscreen is bright and clear. You can control both heating chambers and see the humidity for each one. The one-key preset lets you change filament types quickly. The triple ring sealing and separate chambers keep your filament safe from moisture all the time.
Here are reasons you will like the sh02 filament dryer:
- Auto dehumidification keeps filament dry without extra steps
- Two heating chambers let you dry two spools at once
- Separate chambers let you dry different filaments at the same time
- Real-time humidity display helps you see drying progress
- Simple controls make it easy for everyone
You get peace of mind, better prints, and a smoother printing process. The sh02 filament dryer gives you what you need for great results every time.
SH02 Filament Dryer Results
Print Quality Before and After
You want to see real changes in your prints. The SH02 Filament Dryer makes a big difference. When you use wet filament, your prints look rough and weak. After drying your filament with the SH02, your prints come out smooth and strong. You notice fewer bubbles and no more stringing. Take a look at this simple comparison:
Print Condition |
Surface Finish |
Strength |
Issues Found |
Wet Filament |
Rough |
Brittle |
Bubbles, stringing |
Dried Filament (SH02) |
Smooth |
Solid |
None |
You get better results every time you dry your filament. Your prints look professional and last longer.
User Experiences and Testimonials
People love using the SH02 Filament Dryer. You hear stories from users who see big improvements in their prints. Here are some things users say:
- They find the SH02 keeps filament dry and ready for use.
- The touch screen controls make it easy to set up and start drying.
- One-key presets help you pick the right settings fast.
- Many users say their prints look much better after using the dryer.
- The build quality feels solid and reliable.
Tip: If you want to avoid failed prints, keep your filament in the SH02 between projects. You will always have dry filament for your next print.
Consistency in Every Print
You want every print to turn out great. The SH02 Filament Dryer helps you get the same high quality every time. You do not have to worry about moisture ruining your filament. Your prints stay strong and smooth, even if you print often. You can trust the SH02 to keep your filament in perfect shape. Your projects finish without jams or breaks. You spend less time fixing problems and more time enjoying your prints.
Using the SH02 Filament Dryer
Setup and Operation Steps
It is simple to start using the SH02 filament dryer. Just follow these steps to get your filament ready:
- Turn on the SH02 and look at the screen.
- Put your filament spool inside the chamber.
- Pick the right temperature for your filament.
- Check the temperature on the touchscreen.
- Begin drying and watch the progress.
- Print your model when the filament is dry.
The SH02 filament dryer dries many types of filament well. It keeps things easy for you. The controls are simple, so you do not waste time.
Tip: Always check what temperature your filament needs before drying. This helps your prints stick together and stay strong.
Best Practices for Filament Care
Taking care of your filament gives you better prints. Here are some mistakes you should not make:
- Do not use a microwave or toaster oven to dry filament.
- Never leave filament alone while it is drying.
- Do not set the temperature too high for your filament.
- Do not dry filament in sunlight.
- Keep filament away from wet places after drying.
Use this table to see the best drying settings for your filament:
Filament Type |
Recommended Drying Temperature (°C) |
Recommended Drying Time (Hours) |
PLA |
65 |
4 |
ABS |
80 |
4 |
Nylon |
90 |
At least 4 (up to 24 if very wet) |
Other good tips are:
- Use the right temperature and time for each filament.
- Do not dry filament longer than needed.
- Store dried filament in sealed boxes with desiccants.
Integrating with Your Workflow
You can use filament dryers every day. Keep your filament in the SH02 when not printing. This keeps it dry and ready to use. Store extra filament in sealed containers for later. The SH02 filament dryer is easy to use and saves you time. You use less energy and have fewer failed prints. Your work goes smoother, and you can make more things. Filament dryers help you avoid problems and keep your filament in good shape.
Why Pick Sovol SH02 Over Other 3D Filament Dryers
Versatility and Compatibility
You need a filament dryer for all your 3D projects. The Sovol SH02 filament dryer works with many filament types. It dries PLA, PETG, PC, ASA, ABS, and TPU. This dryer heats up quickly. It reaches 50°C in 7 minutes. It gets to 70°C in 25 minutes. The big touchscreen is easy to use. You can choose the right settings for your filament. You do not need to worry about switching filaments. The triple ring seal keeps moisture out. Your filament stays dry, even when it is humid.
- Many people in 3D printing groups like the SH02 for its speed.
- Users say it keeps filament dry, even when the air is wet.
- You can use this dryer for almost any filament you own.
Efficiency and Safety
You want your 3D prints to look good every time. The Sovol SH02 filament dryer uses a 150W heater for even heat. It dries two spools at once, so you save time. The triple ring sealing system keeps moisture away. The 3.9-inch touchscreen is simple to control. The dryer checks its temperature, fan, and mainboard all the time. Overheat protection keeps your projects safe. You can dry filament for up to 98 hours if needed.
Sovol SH02 Filament Dryer Highlights |
Heating Power |
150W heater with even heat |
Max Temperature |
Up to 70°C for specialty 3D filaments |
Heating Speed |
50°C in 7 min, 70°C in 25 min |
Touchscreen |
3.9-inch, one-touch presets |
Sealing System |
Triple ring sealing to prevent moisture |
Safety Features |
Overheat protection, real-time monitoring |
Drying Duration |
Up to 98 hours |
Fan Type |
3-wire self-checking fan |
Filament Compatibility |
9 types, including PLA, PETG, PC, ASA, ABS, TPU |
The SH02 filament dryer helps you relax. You can focus on your 3D designs because your filament is always ready.
Value for All Users
You want a filament dryer that is easy and saves money. The Sovol SH02 filament dryer has a touchscreen for simple settings. You can dry two rolls at once. This is great for big 3D projects. The dryer helps you avoid failed prints and wasted filament. This saves you money over time. Beginners like how easy it is to use. Advanced users enjoy the smart features and strong performance. The SH02 filament dryer fits into any 3D workflow.
Other Filament Dryers |
Temperature Range |
35°C - 70°C |
Varies |
User Interface |
Touch Screen |
Varies |
Filament Capacity |
2 rolls |
Varies |
Intelligent Timing |
Yes |
Varies |
Uniform Heating |
Yes |
Varies |
- Beginners think the filament dryer is easy and useful.
- The dryer lowers failed prints and saves filament.
- You get a reliable dryer for all your 3D needs.
If you want a filament dryer for any job, the Sovol SH02 is a smart pick. It stops moisture, keeps filament in good shape, and makes every print better.
You want your prints to look good and be easy. The Sovol SH02 Filament Dryer helps you make strong and neat prints every time. You can count on it to dry filament fast and control the heat. Many people who use 3D printers say it helps them print better, even when the air is wet. Users notice their prints stick together better, need less fixing, and turn out well.
Try the SH02 to see how your prints get better. Dry filament and easy buttons help you finish every project.
- Heats up quickly so you can print faster
- Keeps filament dry for a long time
- Works well with all kinds of materials
How do I know when my filament is dry?
You can check the humidity level on the SH02’s touchscreen. If the reading is low and your filament feels smooth, it’s ready to use. You’ll notice your prints look cleaner and stronger.
Can I dry different filament types at the same time?
Yes! The SH02 has two chambers. You can dry PLA in one and ABS in the other. Just set each chamber to the right temperature for your filament.
Is the SH02 safe to leave running?
Absolutely. The SH02 has overheat protection and real-time monitoring. You can let it run while you work on other things. The dryer keeps your filament safe.
What filaments work with the SH02?
Filament Type |
Compatible? |
PLA |
ABS |
PETG |
TPU |
ASA |
PVA |
PC |
PA |
PP |
Do I need to clean the SH02 often?
Not really. Just wipe the inside every few weeks and check the seals. Keeping it clean helps your filament stay dry and your prints look great.
